So when there is no where you have access to like Amateur Radio or direct Radio Transmission?You'll need a DMR repeater with a TCP/IP network connection, and the appropriate software on the device to talk to the repeater and process the GPS data.
sure thats the illegal way...Or DSD+ or some similar SDR decoder could be used to parse the GPS pings.
I have no idea what that means.So when there is no where you have access to like Amateur Radio or direct Radio Transmission?
It's no more or less legal than scanning and decoding unencrypted digital voice traffic. In DMR, the GPS pings are unencrypted, meaning they are perfectly legal to decode in most jurisdictions.sure thats the illegal way...
Amateur Radio Yes, Company Radio No.It's no more or less legal than scanning and decoding unencrypted digital voice traffic.
DSD isnt legal because the break the copyright law.meaning they are perfectly legal to decode in most jurisdictions.
There must be an Software to Send and Receive Data.Connecting the programming cable disconnects both the speaker and microphone, making that data connection pretty useless for sending or receiving digital data through the radio
In the US it is legal to listen to amateur and business communications. Encryption is not allowed in the amateur bands, but it is allowed in the business bands. Decrypting encrypted radio traffic that is not intended for you is illegal, but listening to the encrypted bitstream without attempting to decrypt it is legal, regardless of the source of the encrypted bits.Amateur Radio Yes, Company Radio No.
You're wrong, at least with regard to US law.DSD isnt legal because the break the copyright law.
Not for a direct cable connection to the MD-380/390, for the reasons mentioned earlier. You either have to use a SDR program like DSD+ and capture the GPS data over the air, or connect to a DMR repeater with a network port.There must be an Software to Send and Receive Data.
the US Law dont apply here.You're wrong, at least with regard to US law.
sure an what come out of the cable text files?Not for a direct cable connection to the MD-380/390
sure dsd cant send data out of an radio and there is no Repeater.You either have to use a SDR program like DSD+ and capture the GPS data over the air, or connect to a DMR repeater with a network port.
His location is cited as "AT" which is Austria...If you're not in the US (surprise surprise) mention where you are. Most RR members are in the US and the assumption is that US law applies when discussing legalities, unless you specify otherwise.
