  #21 (permalink)
Old 01-10-2018, 7:52 PM
Originally Posted by kb5zcs View Post
Is the Zastone the same as the MML.....
ZASTONE | Radio Communication Solution | China Two Way Radio Supplier
Ask them.
Tom
  #22 (permalink)
Old 01-12-2018, 8:50 AM
I like Tom's suggestion, good luck with that.
I bought an MML that was replaced under warranty by my onshore dealer with a Zastone. Other than the small branding label they are physically identical as far as I can tell. The programming software transferred my old settings into the new one without a hitch. There is also a Higrade UV-8DR that appears quite similar and uses the same programming software.
  #23 (permalink)
Old 01-12-2018, 10:34 AM
kb5zcs's Avatar
FYI when running the cn8dr software to read and write to the radio i was being asked a password,with a little more search on google i found a newer version of cn8dr software and now everything is working great i am able to connect to the radio now.........
http://www.qrz.com/db/kg5euu
Brownsville Digital Group A.R.C.
WORKING THE WORLD WITH 5 WATTS AND A RUBBER DUCK.
  #24 (permalink)
Old 02-11-2018, 12:28 PM
Default vaesu uv-8dr programming software PASSWORD???
thanks everyone for some uv-8dr info I found some software at
MATH MARK (FUJIAN) COMMUNICATIONS CORP LTD.
and it seems to work with my bofang/btec x3 mic/uusb cable
but software is asking for a 8 letter password???
anyone know the password ?
there was also a 2.3 GIG software on the net i found but aborted that file when i found the smaller one at meth mark..... hihi
i overpaid for this radio on banggood or some alababa and it was showing a photo of the real yaesu with 50mhz band , this clone is like $50 on amazon-prime.
ko6kl
  #25 (permalink)
Old 02-11-2018, 12:43 PM
Default vaesu 8dr clone chip'n
this guy is programming it , but not seeing any password info...
you can sometime click the subtitle translator on if you try
using a computer to program the uv8dr clone
https://youtu.be/er2tOazFKTY
