Baofeng UV-5R
bigprofitt
Channel 02
R-DCS D051N
R-CTCS Off
T-DCS D051N
T-CTCS Off
Channel 01
R-DCS Off
R-CTCS 192.8
T-DCS Off
T-CTCS 192.8
I cannot get these variables to save even though the system says Confirm.
Thoughts?
chief21
Summer - Western NC; Winter - Tampa Bay FL
If you're trying to do this from the keypad, I believe that the Baofeng radios are not able to make changes to a memory channel from the keyboard. You must delete the original channel and re-enter it in order to make any such changes.
One of many oddities of chinese radios in general.
John AC4JK
teufler
ST PETERS, MISSOURI
Turn the radio on
GO to menu item #40 and RESET the radio
Menu item #14 for either English voice or Voice OFF
Press EXIT on the keypad
Push orange VFO/MR button to go to Frequency mode and program in repeater frequency
Press MENU then push #1 for frequency stepping. 10K for ham repeater use.
Push #13 for CTCSS on transmit for repeater use.
Push #25 for repeater shift. Options are NEG(-) POS(+) or off for simplex
Item #26 for off shift repeater use. You want 00.600 for ham radio repeaters.
Go to item #27 to program in Memory channel
Push EXIT to go to frequency mode again
Program in Repeater INPUT frequency
Push Menu then 27 for Memory channels
save as same channel as repeater output.
See isn't that simple ?
nd5y
Wichita Falls, TX
It's best to use the 2.5K or 5.0K settings.
If he is trying to enter a 15 or 25 kHz spaced channel like 147.015 or 444.025 then he won't be able to if the step is set to 10.0K.
This is only for standard offset repeaters in the 2 meter band.
The best thing to do is ignore the offset unless you plan on operating in frequency mode (VFO) and program the transmit and recieve frequenices separately.
If you want to learn how to do it correctly I would suggest reading about it at the miklor.com web site I posted previously.
