  #41 (permalink)
Old 09-06-2017, 6:39 PM
alcahuete's Avatar
Originally Posted by Australia4001 View Post
Looks interesting , Will this radio do 477MHZ analogue TX ?
No. Unless somebody comes up with a wideband hack at some point, it is currently software limited to 470 MHz.
  #42 (permalink)
Old 09-06-2017, 7:49 PM
KC1UA's Avatar
Scan New England Guru
Just received mine today. I'm surprised to read that no one has had any anti-virus/malware issues with the software.
On my work laptop, Symantec Endpoint stopped it cold. On my home PC it was stopped by Windows Defender and then, when allowed through, destroyed by Malwarebytes. This occurred with the latest version of the software and its predecessor.
Curious as to whether anyone else has come across this "anomaly".
Scott - Scan New England Webmaster
http://www.scan-ne.net
Formerly known as "scancapecod" in this neck of the woods...
Radio Reference MA, RI, & CT Database Admin
  #43 (permalink)
Old 09-06-2017, 8:21 PM
I downloaded the latest CPS software and firmware upgrade from both their website and Facebook on 3 different computers. No warnings or issues.
  #44 (permalink)
Old 09-06-2017, 8:23 PM
Just a false positive. Nothing to worry about
  #45 (permalink)
Old 09-07-2017, 1:23 PM
Default Firmware Update
I downloaded the latest Firmware update from the Radioddity web site but when I run it the program gets an error and says "failed to start" . I havent been able to figure it out yet. Has anyone run into this? I have Windows 8 and everything works fine, I installed the latest programming software with no issues, the 1.1.6 I think it is. But Firmware gives an error. I picked the English from the menu. The first time I ran it the program opened but was all in Chinese I couldnt install so I looked into the folder and noticed it has an English folder so I try that and it won't run.
  #46 (permalink)
Old 09-07-2017, 1:36 PM
Right-click on the Update.exe and select "Run as administrator".. This should overcome any restrictions Win8 tries to impose.
Bill
N4GIX - Ham / WQWU626 - GMRS
VV-898, TK-840(N), 2xTYT-7800, 2xUV5R v2+, HP1, BCD436HP, TMV7A, Ritron RRX-450 Repeater, MD-380, XPR7550, 2xCS800, Bridgecom BCR-40U Repeater, Elecraft KX3 + PX3
  #47 (permalink)
Old 09-08-2017, 9:12 PM
Default No luck yet
Thank you for the suggestion. . I tried running the update as Administrator but I get the same error.. the error message is... "The application failet to start because it's side by side configuration is incorrect " .... anyone recognize that error ? Windows 8.....
  #48 (permalink)
Old 09-09-2017, 3:51 PM
The problem may be related to C run-time libraries of Visual Studio (used for to support the CPS application).
Here's a couple of suggestions:
https://answers.microsoft.com/en-us/...c73f460?auth=1
https://answers.microsoft.com/en-us/...2-3a728f4721b1
  #49 (permalink)
Old 09-09-2017, 4:56 PM
Has any uk buyer got a codeplug working for this gd-77?
  #50 (permalink)
Old 09-11-2017, 8:16 AM
jje64's Avatar
Default Excel Import/Export?
How does one make this work with the GD-77 SW? I have version 1.1.6. I see no "import" or "export" buttons in the software.
Also, is there a format for how you enter the data into the excel file to load the CPS with freqs/CC/TG/etc?
TNX
jje64
  #51 (permalink)
Old 09-11-2017, 9:55 AM
KC1UA's Avatar
I have what I believe to be an unusual issue occurring with my GD-77. As far as I can tell the radio acts like it's in promiscuous/monitor mode regardless of the fact that I have that feature toggled off via the button I have programmed for it.
If I have the radio sitting on a tallkgroup that uses slot 2, I hear traffic from any of the others that are also using slot 2 when they become active. This also happens on slot 1. All talkgroups seem to be correctly set up and are in appropriate contact lists.
Curious if anyone else is experiencing this issue and if so if there's a fix for it. The option to monitor everything is nice, but I'd like to be able to defeat it as well. Thanks.
  #52 (permalink)
Old 09-11-2017, 11:15 AM
Default GD-77
I received mine last week. Using the latest firmware and CPS, I have not experienced any problems other than operation being different than my other DMR HTs. So far the only negative is the display falls short of any of my other DMR radios.
  #53 (permalink)
Old 09-12-2017, 11:01 AM
KC1UA's Avatar
Lightbulb It's a "Feature"!
Upon further investigation it appears my "problem" is the current normal behavior of the radio.
1. All talkgroups must be part of an RX Group List in order to work.
2. As a result, when a particular talkgroup is selected, ALL talkgroups that are part of the RX Group List are being heard.
3. The CPS software shows the following in the HelpView when in a channel configuration and the RX Group List is clicked on:
Associates any available RX Group list to the channel for reception. The user can listen to any Group in this list when there is any activity on it and talk back within the Group Call hang time. This is also known as a Group Scan. Selecting the None option disables the user from receiving any Group Calls on this channel, except when the Call ID is the same as the Call ID of the transmit member. The Call ID from the Contact Name is automatically added to the RX Group List on this channel by default. This allows the user to receive this call, even though this feature is set to None. This is a channel-wide feature.
Setting the Rx Group List to "none" as it suggests results in not being able to hear anything.
4. A Powerpoint presentation available at the main Radioddity Facebook page indicates the following:
  • RX Groups are also known as receive groups
  • Currently the GD-77 requires RX groups to receive DV
  • You can setup one talk group per RX group or*
  • You can setup many talk groups per RX group.* This acts likes a scan of the RX groups on that time slot.
  • The RX Group "scan" cannot be turned off or nuisance deleted. *This is the main drawback of RX Groups.
  • RX Groups are way faster than a scan list!
5. Other users of the radio are beginning to post the same issue, again in the Facebook groups. There are two of them, the aforementioned and a separate "Radioddity GD-77" group.
6. In my case I am using the newest firmware and the newest CPS.
7. Monitor mode is NOT activated when this is occurring.
Hopefully this can be resolved with a firmware update. It would seem that the easiest solution would be to not require a talkgroup be part of a RX Group List. I'm not griping, a dual band radio for $86.99 delivered is a pretty darned good deal, and you get what you pay for. I'm impressed overall with the performance and it is an ideal all around amateur/GMRS radio that's a perfect knockabout with minimal loss if something happens to it. That said, when I'm monitoring a particular talkgroup I won't want to hear all of them!
  #54 (permalink)
Old 09-12-2017, 1:07 PM
Until and unless the programmers can fix the firmware to enable single TG reception, using the Rx List is the only way to receive audio.
Creating a separate Rx List for each Talk Group is not a workable option since we are limited to only 16 Rx Lists, and many of us have more TGs than that!
Bill
  #55 (permalink)
Old 09-15-2017, 3:46 PM
Default Rx Groups
My GD 77 has the same issue as far as receive of talk groups. I only have 8 talk groups programmed but no matter what one I'm on if another one comes active it changes to that group until they unkey. So I'm assuming I have to have a separate RX folder for each Talk Group for it to only hear the one I'm on? Right now I have all 8 groups in the RX Groups folder. Now I'm thinking I have to put each one in a separate RX folder ? I know if you don't put any in your Rx folder you wont hear anything, I found that out. I have anything that points to scanning turned off, but if a Talk group becomes active my radio still changes to it as if it's in a scan mode. That needs to be fixed in the software. The TYT radios don't have that issue.....
  #56 (permalink)
Old 09-18-2017, 11:26 AM
Does this radio support roaming? and how do you make roaming work if it does? very new to DMR. just ordered one of these of amazon
  #57 (permalink)
Old 09-18-2017, 11:40 AM
Forts's Avatar
Mentor
No it doesn't. You'll have to manually pick the repeater/site that you want. Same as any other low end DMR radio.
  #58 (permalink)
Old 09-18-2017, 11:43 AM
ah bummer. so none of these ~200 dollar radios support roaming huh? I wonder why. I'd think it's a software programming thing. Not hardware related adding to cost...
I'm hoping this is a good radio to start out with. I really wanted the dual band... however reading some stuff here where it monitors both timeslots no matter what, and 16 rx doesn't sound too exciting. Looking at a G55+ or a MD380 too now...
  #59 (permalink)
Old 09-18-2017, 11:47 AM
So far only Motorola, & Hytera radios support roaming. When you buy a DMR radio for under $100, it has few, if any features. By spending more, you get more. Just like buying a car, or anything really.
FORMERLY MOONBOOTS
  #60 (permalink)
Old 09-18-2017, 11:53 AM
Forts's Avatar
Mentor
For $80 or whatever it was, I think the 77 is a great buy (especially considering it's dual band). I carry mine with me all the time (I'm not a ham btw so I have no need for global contract lists etc etc). Many of them job sites I visit use UHF MotoTRBO and I have authorization to be on their systems, so it works great there. I'm also a firefighter so I can use the VHF side to monitor local dispatch channels. Under no circumstances would I use this radio on a fire scene (have an XPR7550 for that) but it works great for RX only.
