I've heard that some improvement to range can be achieved by replacing the antenna that comes with some of these radios with a better one.
I have a Baofeng UV-6 that is a VHF/UHF 5w/4w radio. The antenna has a female SMA (Thanks, Jon!)... I would use it more in the UHF range than VHF, but it would be good if an upgraded antenna worked for both.
I'm quite aware that these are very low-cost radios not worth much and have issues other than their antenna, however, I'm only looking for recommendations on upgraded antennas that don't break the bank. However, if you think that upgrading the antenna won't help these radios at all, then that'd be good to know!
Thank you for any suggestions on the antennas.
