  #81 (permalink)
Old 07-05-2018, 11:19 AM
thanks to all....
if a a new radio and update, in how mode with the keyborad in the VFO mode i set "temporanealy" an number for an TG "no" in my codeplug ?
73
  #82 (permalink)
Old 07-06-2018, 2:28 AM
??? NONE use thi very amazing feature to put with the keyboard an a new TG (talk group) "on the fly" ?
  #83 (permalink)
Old 07-13-2018, 12:02 PM
To call a group just use the "Private Call" feature where you call a private contact ID directly. Prepend the group ID with the '#' key.
In other words:
1. Go go Menu / Contacts / Manual Dial
2. In the dialog press # key
3. See it switched to "Group ID"
4. Enter the Group ID and press PTT.
  #84 (permalink)
Old 07-19-2018, 10:42 AM
thanks LeEik !
in the new update 2.30 FW i read :
Below are the user friendly operations in D868UV
1. Allow mix the digital mode and monitor mode in RX.
2. Single slot/double slot digital monitor set up
3. Allow set up the audio pitch to get more suitable audio during DMR
communication.
4. Allow response to the last caller with a programmed key.
5. Allow send the recording to the other user or group.
6. Allow get the remotely GPS positioning information, it is useful
especially in outdoor team touring.
7. Headset volume set up to avoid the loud volume heart the ear.
what are this new features tell to me in simply mode ? tnx ....
  #85 (permalink)
Old 07-20-2018, 4:08 AM
HELP ME.....
in how mode :
1) i inverted in the display the Call with the name (now the call is red and little ) !
2) delete the screen at the end of conversation END CALL .
3) why i press the function key programmed SCAN it not start the scan, where is
the problem ?
73
  #86 (permalink)
Old 08-03-2018, 10:17 AM
After the Update FW 2,30 of june ….
V1.31 and FW V2.31 Improvements (updated 2018-7-14)
1. In CPS->Optional Setting->Power-on, add the Default Startup Channel and zone, it will allow you
choose a startup channel, every time when you power on the radio, you will be at the start up
channel.
2. Menu->Settings->Chan Set, add Select Contact, allow to choose a Contact and save the changes
to channel.
3. Allow create a new channel on radio or delete an existing channel . Operation as below.
Create a new channel: Hold pressing MENU key, until the LCD display “Next Please Press Dial Key”,
press P1 key, the radio will enter into new channel setup.
Delete an existing channel: Turn to the channel firstly, hold pressing MENU key, until the LCD
display “Next Please Press Dial Key”, press P2 key, the radio will allow deleting the channel.
73 de IW2BSF Rudy
  #87 (permalink)
Old 08-09-2018, 9:18 PM
I read through this entire thread concerning problems with OpenSpot but didn’t see any solutions. I have a new 868 running V2.30. OpenSpot parrot (9998) works fine but otherwise can only receive BM network. My transmission never hits the network. Also have an MD380 which works fine through the OpenSpot. Any suggestions?
Ray - K2DEE
  #88 (permalink)
Old 09-01-2018, 5:55 AM
Default Any experiences with 5 tone?
I need the following:
1. RX always open (in analog mode)
2. two different 5 tone sequences which can be choosed i.e. on Channel 1 (11111 and 22222)
I programmed in Analog Address Book the 2 sequences as 2 numbers (1=11111 and 2=22222).
I programmed under Analog-> 5 Tone Setting the 2 Encode IDs (11111 and 22222)
How can I choose and send the 2 different sequences? With Alarm button or Call button?
What is in Alarm Setting, "Alarm", "Transpond+Background", "Transpond+Alarm" or "Both"?
Thank you for your help guys!
Chris - DG2NGI
  #89 (permalink)
Old 09-01-2018, 10:59 AM
mcscanner's Avatar
Ray - K2DEE
Try 9990 as a parrot. I still trying to figure out DMR on a ZumSpot. Not so much how to program the hotspot, but more about programing the radio to work with this device and using Brandmeister and DMR+.
I've listened to many YouTube tutorials and I lost count.
DStar is a walk in the park.
Good Luck,
P.S. My radio is a 868 too.
The road goes on forever and the party never ends...
  #90 (permalink)
Old 10-24-2018, 10:32 AM
Default Not hearing the TG
I have read through the posts and I don't see an answer to the issue I am having sorry if I missed it. I have programed several DMR radios and have never run into this issue. I can be heard on the TG but unless I am in Monitor mode (promiscuous) I don't hear the TG I am on. I have the "receive goup list" set to none so it should be hearing the TG I am on. This is happening with both repeaters and hotpots so before anyway say try the off-set its not the off-set. I must be missing something but I for the life of me cannot figure out what, Interesting enough if I make a receive group with that TG number it works fine.Thanks in advance for any help
  #91 (permalink)
Old 10-24-2018, 11:10 AM
mcscanner's Avatar
I use none on all my channels without issue and not sure what to make of it working with a receive group w/ number.
Needing to use promiscuous mode suggest time slot issue, wrong one(?). My Zumspot (hotspot) works simplex using slot 2. Between repeater and hotspot channels they would be different and an easy point of confusion, assuming your hotspot is similar to the one I'm using.
Connectsystem just posted a couple of days ago the latest Firmware/CPS (2.33) file. If you are not up to date maybe that will help.
Good Luck,
  #92 (permalink)
Old 10-24-2018, 11:19 AM
Yeah its bizarre and that was the first thing I thought was I had the time slot wrong . Yes I am running 2.33.
  #93 (permalink)
Old 10-24-2018, 3:03 PM
mcscanner's Avatar
Maybe some corruption in the codeplug.
Start from scratch in the CPS and only program the minimum to test and see if you still have the problem. I’m not at the main computer, but export your current codeplug in DCF (?) format and take a look in Excel if you can to see if anything look fishy. I think it’s a csv file that needs an extension name change to open in Excel. Another possibility is use Contact Manager by N0GSG on the DCF file. Something might turn up in there.
  #94 (permalink)
Old 10-29-2018, 9:43 PM
NYG NYG is offline
I just picked up an AT-D868UV at a hamfest yesterday. My first time dealing with DMR aside from using my scanners or DSD with SDR gear.
I'm working my way through learning the radio and DMR programming in general. Having a DMR transceiver really forces you to learn a bit more which isn't a bad thing.
I have to say the digital audio quality of this radio is fantastic.
