TYT-MD380 Menu button not working
Experiment626
Hello, after upgrading the firmware a while back, the menu button on my md380 stopped working. I have tried going back to several older firmware releases, but that doesn't fix it. Does anyone have any ideas on this? Thanks.
Cyberider
Tempe, AZ
Keyboard Locked
I, too, have this problem, even though I've never updated the firmware. Following the unlock procedure in the instruction manual has no effect, other than tell me that it's locked. It will tell me this only once unless I turn the radio off and back on again. I don't know how long it's been this way because I rarely use the keyboard. Radio works fine, otherwise. Sure would like to find a solution if anyone knows of one. Thanks.
namitutonka
Denver
Hello,
I am in the same position. Did you find a solution ?
Keyboard Locked
I, too, have this problem, ....
My menu is now working. I'm able to select everything using the arrow keys. Had the same problem with a locked keyboard even after nearly a dozen different firmware .bin file flashes. Strangely, it changed for the better after flashing freshmd380.rdt from Programming | You and Your Tytera MD-380 DMR | Adafruit Learning System The download link fresh380rdt.zip is in a green box less than halfway down the page. The thread and download concerns the non-GPS MD-380, but I flashed it anyway onNow I don't have a TYT Model:MD-380G paperweight. For flashing fresh380.rdt I used TyteraFlashTool_v1_08c_BETA which I got from Télécharger Logiciel TyMD380Toolz de KG5RKI : Flash tool / MAJ firmware et contacts UserDB | OPEN DMR
Hope you have good luck with the .rdt file like I did.
73's, KC0BMC Mike in Denver
Aanother interesting MD-380 link is rct's notes: Read and Backup Tytera MD-380 calibration settings.
