jimlawrence
- Joined
- Apr 17, 2004
- Messages
- 286
Greetings! I am trying to upgrade the firmware on my MD2017. I've followed the instructions carefully but it won't complete the upgrade. It seems to download the new firmware file just fine for about the first half of the process, then, the little bar at the top jumps to the right, then jumps back to the left, then just stops. After about 15 seconds, I get a little pop-up box that says the Upgrade was successful. But when I power the radio off, then power it back on again, I see the initial power-on screen, then, nothing. It just hangs there.
I can still upload and download my codeplug using CPS 1.17. But the firmware upgrade fails repeatedly and always in the same manner.
I've tried uploading both versions 3.33 and 3.40. Both fail to load.
I'm using CPS 1.17, which works fine. Windows version 7.0
Thoughts? Ideas? How do I remedy this and get the new firmware into my radio? For instance, is the install program (UpgradeDownload) looking for some files associated with CPS 1.17 and so all the extracted files should be in the same directory?
Thanks!
Thanks!
