ki7ryg
I apologize in advance if this is in the wrong place (moderators are free to move it if it is). I just got my technician license last month and attempted to install a mobile unit into my 2004 Jeep Wrangler X.
I'll try and upload photos here in a bit so as to visually aid anyone in helping me, the radio turns on just fine and I can listen to my local repeater without issue. The problems come when trying to transmit.
(1) After holding down the PTT button, the radio begins to let out a repetitive chirping sound. Nothing in the manual gives an explanation as to why it's doing this (*will insert YT link of sound with photos*)
(2) When I press the PTT button, I've been told by other listeners to "speak into the microphone", though I am already talking.. Which leads me to believe that while I am connecting to the repeater just fine, I'm not actually transmitting anything for some reason.
I've checked and verified (3 times) that all settings needed to connect to the repeater are accurate.
Simplex results in the same problem: I had a friend on the same frequency and attempt to transmit, he said his radio behaved as though it was receiving a signal, though he could not hear me talking.
Setup:
TYT TH-9800 quad band transceiver
HH-9000 Quad band antenna
Radio recommends 12v of power and on startup will readout the power input from the battery. When the Jeep is off it gets roughly 12.1v and when running it was getting 14v, in both cases it's on a 15amp fuse (though the radio originally came with 5amp in-line fuses - I cut the in-line portion so I could route the cable through the firewall to a Blue Sea Systems fuse block).
Originally I thought the issue was the TH-9800 unit itself, so I ordered another one off Amazon and tried plugging it in, but I got the same results. So the only conclusion I have thus far come to is either I received 2 bad radios in a row, or I've gone and set something up incorrectly (being new, it wouldn't surprise me).
Any help would be greatly appreciated.
Setup:
