Baofeng / Chirp / RadioRef error
jonathany1
Pekin, IL
Using chirp to program Baofeng UV-5R
I am able to import from all zip codes in my area except the zip codes in one particular county.
If I select ANY zip code in Tazewell County, IL I get the following error: <unknown>:1:1401: not well-formed (invalid token)
This has been going on for a few days at least now. It has worked fine previously.
ko6jw_2
Santa Ynez, CA
Chirps interface with RR is somewhat problematical. Not all of the database seems to be accessible. I have not found a way to access nationwide or statewide frequencies that don't have a county associated with them (or a zip code). On the other hand, some scanner specific software can access this information. I don't think it's RR per se. I think Chirp is the problem. I have other software for Yaesu radios that does the same thing.
I exported from RR into CSV files and then imported them into other software. Not seamless, but it can be done.
ecps92
Taxachusetts
Might be related to the error impacting many of the Software being used by members.
See
https://forums.radioreference.com/scanner-programming-software/364446-psredit500-error.html
https://forums.radioreference.com/v...ro96com-error-when-importing-rr-database.html
