Old 02-08-2018, 6:30 PM
Default KG-UV9D Plus not showing channel names
I just bought a KG-UV9D Plus and I downloaded the software from Powerwerx's website. I put a bunch of channels in the programming and I assigned channel names to each one.
When I write to the radio, the radio still shows CH-001, CH-002, etc. It doesn't show the name I used in the software.
I read the radio back out to make sure the names had written were there, and they were all there. So it's in the radio, but it's not displaying it.
Anyone know how to fix that?
Old 02-09-2018, 5:58 PM
I figured it out. Turns out the memory button cycles through the CH-001, the frequency and the channel NAME. This is shown in the manual, but only in a diagram, the text doesn’t explain it.
Old 06-17-2018, 9:28 AM
I have this problem too, I still only see ch1 etc. How did you fix it?
Old 07-27-2018, 9:13 AM
Try to cycle twice thru the channel modes. It shoes first frequency then "ch-01", followed by frequency again and the actual channel name. Just press and hold to cycle though it.
