Old 02-11-2018, 6:56 PM
Default UV-82 Programming
When in CHIRP I see lines 22 and beyond are grayed out. How do I gray out lines below 22. If I wanted lines 17-21 greyed out how do I do that? I am comfortable with importing and exporting with .csv files into .img files (I think).
Old 02-15-2018, 10:17 AM
N2SCV's Avatar
Default UV-82
1-Did you click "Show Empty"?
2-Where it says "Memory Range" (top left) should be 0 and 127.
Old 02-15-2018, 6:40 PM
Thumbs up Solved
Yes, answer 2 was what I needed. Thank you!
