Old 04-12-2018, 7:15 PM
riccom's Avatar
Talking My review of the rd-5r
Ok where do I start, as a starter of this dmr world, let me say it is a bit of a learning process, how to enter slots, uid, color codes, and tg aka and listening to a digital voice, and not analog, and the quality of this radio is a lot better then I expected.
The look and feel:
Well it is like any other uv family radio, as in cosmetics and feel, the antenna is better built then the normal baofeng antenna, (it is a radioditty rd-701 antenna), and the signal, is ok, at least no front end issues, (thank god, I live near major radios towers).
The display is nice but I wish it would be color changing if not on the led , but on the screen it is crisp, but the white leds are Diffrent then what I am used to, but it is a ok thing I guess.
The meat and potatoes of the setup and operation of the radio, it is simple if you know a dmr code plug, if not, do the homework , it will help, the basic is ok, but I myself, have a lot more to learn, and looking at the threads on here,
The operation of the radio, is good, I have a few dmr channels on here listening and comparing to my scanner, it is night and day, no static, and on a 40 watt system I can get good signal at 25 miles away,.
I do like the front panel programming, but I have yet learn how to save it, to the main scanning banks on it. Maybe some one knows how to,
I am still learning this thing out, but from what I can tell, it is awesome.
Rd-5r pro-2062 bf-8hp beojie 218 bc335c qyt 8900D and a partridge in a pear tree!
Old 04-12-2018, 9:27 PM
Thank you for the review. I hope this radio does not inherit the issues present in the radio this is based on, the Radioddity GD-77.
https://forums.radioreference.com/bu...ml#post2913445
Old 04-12-2018, 10:34 PM
riccom's Avatar
I heard about that, but mine does not have that issue at all I have about 600 channels loaded up and all by state or ham or police and fire and ems, and miscellaneous stuff, no issue at all
Old 04-14-2018, 2:58 PM
mikew66's Avatar
What software are you using? Did you make your own code plugs?
Old 04-15-2018, 11:30 AM
riccom's Avatar
I did make my own code plug, I used an old one from a web site to use as an example to go by, and I get amr ambulance and it is encrypted I know but as a test on what I could do, then used the Nucor system and get them in the clear, and if and when I do some traveling I know how to enter them
Old 04-21-2018, 7:15 PM
riccom's Avatar
*Update* sadly when I finally did the upgrade to the firmware my transmit audio is gone, so since this is a huge issue I am going to say if this a issue I will not be giving this a good mark
Old 04-29-2018, 9:23 PM
riccom's Avatar
(in a robert stack voice) UPDATE, since the new firmware is not working it seems to be an analog issue with the rd-5r, now the new radio i have is doing the same thing with the beta, now i do have the digital side working and the older one is still having issues not keeping up with the dmr decoding, , now i know it is a beta but i will put in some input on this
Old 04-29-2018, 10:06 PM
I have had no trouble with the GD-77 and 3.1.1. One thing I do, which does take time, is to build every code plug from a clean database, including the talk groups and individual receive groups. I have 8 different radios, and it is not just the GD-77 that requires individual receive entries.
Old 04-30-2018, 10:06 PM
riccom's Avatar
ok here we go, turns out they sent me another radio, this time the new update killed the analog side of the new and older radio, seems that radioditty has a big issue on there hand, and if they wont fix it soon, then we may need to have a pow wow with them to get this issue fixed, this will cost us and the sellers money!
Old 04-30-2018, 10:38 PM
mikew66's Avatar
I returned mine and bought an AnyTone D868UV. Very easy to program, great customer service, and I found a lot of code plugs for it for my area.
Sent from my SM-G950U using Tapatalk
Old 04-30-2018, 11:39 PM
riccom's Avatar
<<<<< cheap here, i used my bonus money to get the radio so that is out of my budge
Old 04-30-2018, 11:40 PM
mikew66's Avatar
Just put it on a credit card ha ha!
Old 04-30-2018, 11:49 PM
riccom's Avatar
yeah no, i am debt free and if i can not afford it i do not need it
Old 05-13-2018, 1:45 PM
usswood's Avatar
After some programming errors on my part, I LOVE my RD-5R!!! Strong transmit signal and great range for this little piece of equipment... I to had issues getting to digital side to transmit correct, but after a few tweaks of the setup, I couldn't be more happier with this model!
usswood
Old 06-19-2018, 1:55 PM
Could someone be some assistance to me on helping me program the rd 5r? I got the new software and it seems to have a virus or something. Each time i try to program it , the radio is harder to operate. Ive managed to get some freqs in but it will not scan. Any advice would be appreciated
Old 06-20-2018, 9:07 AM
Excellent choice!
John KD8DVR/WQWK521
All comments may or may not resemble actual fact. Any message posted constitutes opinion only.
Old 06-20-2018, 1:57 PM
usswood's Avatar
I could send you a code plug, but it is setup for Hoosier DMR and sites close to Indiana... Don't know how useful it would be for ur area?
usswood
Old 06-22-2018, 2:51 PM
I would be interested. The code plug I used for my TYT-380 came from Hoosier DMR, but I don't see a spot in the codeplug vault for a RD-5R plug
73 de KN4INT
Old 06-29-2018, 11:43 AM
rgchristy's Avatar
Is it possible to program, even if for receive only, frequencies between 500 & 512 MHz. I've looked at the CPS and it appears so, but I was wondering if someone could please try it on an actual radio.
Thanks.
Old 06-29-2018, 1:44 PM
usswood's Avatar
73 de KN4INT
you have to post your email address, I can't send you a PM
usswood
Tags
baofang, dmr programming, dmr radio, radioddity, rd5r
