TYT MD390
GI4OHH
NON GPS
it wont go by the welcome screen its stuck in a loop any help to try get it back up and running would be very helpful thanks in advance
bjornepappa
Did you upgrade the firmware? If so, are you sure you have chosen the correct?
Sent fra min SM-G930F via Tapatalk
GI4OHH
firmware
yes upgraded to experimental firmware it worked ok after installation then i turned radio off when turned on again it started this went back to original firmware and it’s still the same
bjornepappa
Are you 100% sure that you used the non-gps firmware? And are you 100% sure you have the non-gps radio?
