I've done a little bit of research to try and find a budget / value for money Chinese made radio with a good 'front end' receiver in it. The Baofeng UV-B6 and UV-B6 are consistently mentioned for their good receiver characteristics in terms of overload, selectivity & sensitivity.
Are there any others out there that would receive similar recommendations? (Bonus points if you *know* that your recommendation uses an AT1846S radio IC within)
Ultimate aim is to see if there's any difference in the parameters (there are many!) being sent to the AT1846S that strike just the right balance for optimum receiver performance, and then use that data so it can be applied to *any* radio using the same IC.
