Old 05-19-2018, 11:31 AM
Default MD-2017 White screen
I have been having an issue with my MD 2017 where when I turn it on all I get is a white screen. The white screen never goes away. My display is ALWAYS a white screen only. I also still cannot connect to my computer. Havenít been able to connect after the first time I was successful the first day I had it. (Christmas Day) any clue what could be up/possible fixes?
BCD396XT // BCD996XT // BCD436HP + DMR Upgrade + EDACS ProVoice Upgrade + NXDN Upgrade + ProScan
Baofeng UV-82WP // TYT MD-2017
Comet DS150S 25-1500 MHz Discone + Comet HS-05 M/J-SMA/P 0.5m
Old 05-19-2018, 2:03 PM
jimvm's Avatar
Did you buy the radio from 2wayradios?
They are going to replace my MD-9600 that had same problem.
jimvm
Old 05-19-2018, 2:34 PM
jimvm
I received it for Christmas. I believe it was purchased from Amazon.
Old 05-19-2018, 3:50 PM
JustLou's Avatar
This is a common issue with this radio, the MD380, the GD77 and similar radios from China. The fix is to open the radio and reseat the ribbon cable connected to the screen and main board.
Old 05-21-2018, 7:14 PM
Does anyone know how to reset the radio itself? Maybe a combination of buttons pressed and other actions simultaneously? I'd rather try a hard reset/restart before opening it.
Old 05-21-2018, 9:52 PM
Re-SEAT the cable...not Re-SET. The cable inside the radio may have come loose. No button pressing will fix a loose connection. If this happened because of a firmware upgrade gone bad, then you can try to restore it to the previous firmware.
Old 05-22-2018, 1:46 AM
teufler's Avatar
you might check, did you install firmware that is not for your radio. GPS for a gps radio and non GPS for the none gps model.., I did this and I had put the wrong firmware for the model I had.
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
Old 05-26-2018, 1:24 PM
I had this same issue. Courtesy of this post, youtube and some other research I opened up the radio, re-seated the screen ribbon and this resolved the issue for me.
Old 06-26-2018, 2:38 PM
How do you get the silver piece off of the radio to get to the internals? I removed the two screws under the battery but no luck removing
