MOTOTRBO/ DMR & TYT MD-390 for EMS
SteveR95
Hey guys. Totally new to the RR community and I have what would probably seem like a silly question for you guys. I work as a paramedic for a commercial EMS agency in NY. After browsing the databases, I found that they’re using the OneVoice Network. My company is cheap and won’t issue portable radios to all the units, so I was wondering if a TYT MD-UV 390 would be able to be programmed by myself for use on this type of network without any special encryption keys or codes. I will be buying it out of pocket, and from my brief research, it seems like a good value hardware. Thanks in advance for any insight you guys could provide.
Here’s the link to their network and talkgroups: https://www.radioreference.com/apps/db/?sid=7363
Josh
Auburn Hills, Michigan
Only a Motorola radio with a Connect Plus option board will work on a Motorola Connect Plus radio system. The MD390 is conventional only.
cg
Connecticut
Fairly sure that system requires each radio serial number to be entered into the system by the radio company. I would bet that they charge based on the number of subscriber units (radios) each customer has on the system. So even if you buy the radio, the company may balk at paying extra money every month for your portable.
chris
alcahuete
Antelope Acres, California
In addition to what has been said above, these cheap Chinese radios should absolutely not be used in public safety, where life and death can depend upon the reliability of your radio. They're great personal radios, but definitely should not be trusted for public safety.
