Old 07-08-2018, 1:32 AM
Phillipsc84's Avatar
Default MD-2017 Buttons not working
So I've gotten a few dual band radios to play with. The Anytone and the newer MD-UV390 plus the MD-2017.
I was curious if anyone else has had the issue with the MD2017 where none of the buttons work? They beep as if they should do something or as if they aren't programmed. This includes the Menu button. You can't get into the menu at all. And even though the other buttons are programmed they don't work. Just beep.
Phillip W -Fort Mill, SC
Owner,
Codeplug Supersite
http://www.codeplugsupersite.com
