Old 07-08-2018, 6:03 PM
mfn002's Avatar
Default AT-868 Won't Update Firmware
I was trying to update the firmware on my Anytone AT-868 and I keep getting an error message requesting me to check that the USB settings are correct. The radio programs fine, but it seems that whenever I run the update app, it won't connect to the radio.
Michael, KI5BPO
BCD436HP*BCD536HP*TRX-2*XPR5550*XPR7550*UNICATION G4
SHSU '13
Old 07-08-2018, 6:05 PM
Are you putting the radio in update mode first?
Old 07-08-2018, 6:13 PM
mfn002's Avatar
No, I didn't know you had to. How do you do that?
Michael, KI5BPO
SHSU '13
Old 07-08-2018, 6:16 PM
I believe hold the two buttons below ptt while turning on the radio..
Old 07-08-2018, 6:20 PM
mfn002's Avatar
Oh, yeah. It only said "Are You Sure You Want To Initialize The Radio?" I saw this procedure in the instructions, but I am unsure as to when I'm supposed to do it. For a little more detail, the error message says, "Check Link. Check whether the current serial port settings are correct, retry or cancel?"
Michael, KI5BPO
SHSU '13
Old 07-08-2018, 6:24 PM
Oh, yeah. It only said "Are You Sure You Want To Initialize The Radio?" Am I supposed to do this while the radio is in "PC Mode"?
You should check the manual if you can. I am just going off of memory and I don't want you to mess something up. I'm kind of in the middle of something right now so I don't have the time to check... This may help
http://www.wouxun.us/category.php?category_id=90
Old 07-09-2018, 10:06 AM
Hold in the red button on top and the PTT while turning on the radio. The only indictation that you are in firmware update mode will be the red light blinking on top. Very clear instructions are included with the new firmware and software.
Old 07-09-2018, 12:42 PM
mcscanner's Avatar
Port number must be selected after radio is on and connected. Use the default baud rate.
The road goes on forever and the party never ends...
Old 07-09-2018, 3:29 PM
mfn002's Avatar
Thanks everybody for all the help. I've figured it out now.
Michael, KI5BPO
SHSU '13
