Got one of these a few weeks ago. There are some issues, but besides these issues, the radio appears to be working OK. I have contacted Retevis support but not holding my breath to see if they will address these issues that I am personally experiencing.
1. The import function for the Priority Contact list does not work. I've been using that list for talk group ID's. I've been manually entering talk group ID's You are supposed to import a .csv file but it is not working. The normal address book will import however. Might end up using the address book for all contacts/talkgroup ID's
2. Backlight: No matter what you set the timeout for, it randomly reverts to continuous
3. When the radio is receiving a signal and you want to change channels, you have to turn the dial about one full turn to get the radio to respond that you are trying to change the channel. Works fine if the radio is not receiving a signal.
CPS used: v.1.93 GPS
Firmware: 1.4.9 GPS
Firmware: 1.4.9 GPS
