Tyt Md-9600 Programming Question
K4KF
Trying to program my MD-9600 for first time. On the surface everything seems to be okay and the software appears to be writing to the radio. However, when the writing is complete the message on the front of the radio says not programed. I can write the original program back to the radio. But every time I try to write something that I have programmed I get the not programmed message. Any suggestions and or help will be greatly appreciated.
Wayne
wrath
Have you read the radio ,before trying to pur ubfo inn you can't write directly without reading each time ?
Sent from my SM-T810 using Tapatalk
K4KF
Try it did not work
Thank you for the suggestion I tried it and still got the not programed message on the radio in both directions. The software indicates all was well, so I am thinking it must be an issue with the radio.
