Baofeng, where get fuses?
AB6CJ
I have a cigarette lighter adapter for my baofeng dual band radio. The fuse in the tip seems to be an odd size. Compared to all the six by 30 mm fuses in the stores, this one is 1/2 a millimeter thinner. Where can I find such a fuse? It's fast acting 3-amp.
AB6CJ
The problem is that the auto stores sell auto fuses, but this one is 0.5 mm thinner.
jonwienke
More Info Coming Soon!
VA
5mm fuses are a standard size. It's probably a 5x20mm, easily found on Amazon or any electronics supply site.
AB6CJ
I asked Baofeng but they said it was a standard auto fuse. But I went to 3 auto stores & tried 3 brands of auto fuses & they were all too thick. The employees confirmed this. The fuse in the adaptor is 0.5 mm thinner than the auto fuses.
The fuse is not 20mm long, it's 30mm long. The 30mm I found were generally 6 mm wide, which are too wide. I checked Newark & Mouser but they just had 6x30, not 5.5x30, which is what I need. I'm beginning to think they don't exist. Even if my adpator is defective, I can't figure out how they found a fuse that will fit. Both I & an employee measured the fuse with a caliper (2 separate calipers) & found the fuse that came with the adaptor is indeed thinner than 6mm.
PrivatelyJeff
Has more money than sense
Kings County, CA
It's brand new. I'd hate to chop it up already.
But sometimes it’s the better option. All of my scanners had crappy antennas so I immediately replace the antennas. Plus it will make it easier to replace the fuse later.
