expert advise needed: Program channel to scan
SSG_Nappi
I had a radio (baofeng 888) that had 4 channels. It was programmed so that channel 4 would scan channels 1-3. I no longer have the radios, so I'm unable to download settings from radio to duplicate can not figure out how to program it this way in chirp. any advice? is it possible this needs to be programmed manually without chirp?
CCRS53
Lineville, AL
Programming help
I've never seen a 888 programmed like that. The only way I can think that would work is if every channel used the same frequency but different squelch codes. If that's the case then you can program the last channel with open squelch (no squelch code) and it will listen to anything broadcast, regardless of tone code. If you already know this, then I apologize, just trying to think what might help! I reviewed the settings in chirp and haven't come across anything else.
