KG-UV9 Plus USB Programming Cable
MaxDonoghue
Kingston, ON
Hi all,
Are there programming cables from other manufacturers that are compatible with the KG-UV9 Plus?
I've probably got a Baofeng cable laying around, or a WLN KD-C1 as well.
Just don't want to spend the money if I don't have to.
Max
wd9ewk
Arizona USA
Hi all,
Max
I use the same cable with my Wouxun KG-UV9D (original and Plus versions) that I use with my Baofeng radios. Give it a try with your radio.
A cable I use for most of my radios (Baofengs, Wouxuns, Yaesu VX-3R and FT-4XR - haven't tried it on everything yet) is a 6-in-1 cable package I got from Amazon:
https://www.amazon.com/KENMAX-Program-Programming-Talkies-Motorola/dp/B01466PL7U/
This cable is also available under other names on Amazon, but the link above is for the cable I purchased last month.
If you need to get a cable, especially if you have other radios, this might be a good way to go. It comes with a mini-CD that has the Prolific driver needed by this cable. I found that the same driver Yaesu uses for its SCU-35 programming cable (used with the FT-4XR, FT-4VR, FT-25R, and FT-65R) also works perfectly with this KENMAX cable.
Good luck!
