Plan on making one soon,,
The canonical dipole is merely:
468 / F in mhz = total feet. Now you can feed that length in the center, or anywhere else offset along it's length, but if you do, you'll want to match impedances to the coax with a transformer. It will work at the design frequency, and also 3x that, with a slight change in the directional pattern.
second question can the home made Dipole lengths be modified from the standard 18" and 48" to receive the desired freq? like shorten one element to receive lower band transmission ?
You are referring to the "OCFD" vertical scanner dipole. It has a natural resonance down near 88mhz, and some other points higher up in the bands. However, it is purposely designed to be "non resonant" on other bands. Resonance isn't always needed for efficiency, and being non-resonant on purpose, the 300:75 ohm (or 4:1 ratio) balun transformer helps bring the impedance down closer to that of 50/75 ohm coax on a multitude of bands.
The major problem is that above the VHF band, where the elements are significantly longer than an ordinary dipole, the radiation angle starts to head straight upwards. Not usually what one wants. HOWEVER, if you live in a very RF dense environment, powerhouse uhf and 800mhz signals will be ok. This pattern-attenuation if you will, also helps with the typical weak front-end of scanners prone to overload. Normally this antenna is not mounted in the most ideal places, and uhf and 800mhz reception can rely on strange angled reflections to help.
So in the end, it is an easy-up Saturday empirical goof project. It works for many as a first time bedroom antenna, far better than the usual back of set whip - but to be sure, you'll never see one on a hilltop connected to commercial gear.
Caveat - since this antenna is broadband, with a scanner you may also be susceptible to FM broadcast overload, or a multitude of other powerhouse signals that can desense the front end.
Essentially, you just try it, and if it doesn't work - ball it up and toss it.
