I am trying to build a discone antenna with a frequency range of 30-512MHz. Can someone point me in the right direction in how to build one with this bandwidth?
I was researching the internet and came across a few documents on technique used. All of these documents base the size according to the lowest frequency, but I also want to set the upper bound
These are the documents I found
https://26hs4316.wordpress.com/antenna-construction/discone-antennas/
UHF Discone Antenna
http://kd0cq.com/downloads/Antennas/discone.pdf
UHF Discone Antenna
