HeavyThumper
- Joined
- Sep 10, 2015
- Messages
- 5
Got a question - not sure where to ask it. Hopefully someone here can at least point me in the right direction.
I use a radio monitoring system that operates on a licensed UHF frequency (465Mhz). The manufacturer of the radios provides some simple cheap antennas - I've been exploring some quality aftermarket options and gotten very surprising performance. But I have an usual situation I'm trying to remedy.
Normally, these radios are each themselves repeaters for my network. So the more I add the better my overall network performs. But I've got a new location that's very RF unfriendly. The primary sending unit is located on the 1st floor inside an electrical room - that's where the monitored equipment is. Signal reception in & out of this location is poor. So...
I went up to the roof on the 4th floor, there's a supply closet, where I've installed a second radio to act as a relay. This relay sees the rest of the city, and the 1st floor is able to communicate with the relay. So...communication link established. And this communication is approximately 50' vertically from the 1st floor to the roof, and about 100' horizontally, and of course is through the floors/walls. The communication to the closest remote links in the city is a few miles.
But it's not a very strong link in either direction. Let me explain more. The standard antennas used for these radios are simple 8" "rubber duck" type. I know just enough theory to get into a lot of trouble...I know the top of the radio's metal cabinet normally provides the ground plane for the antenna. So that is indeed the case for the 1st floor location. Now, the 4th floor location - the radio is inside the closet, and the antenna is mounted on the outside. That external antenna is another simple rubber duck - but it current has no ground plane.
The radio locations have to remain as is - for reasons of power & physical security.
Now that I've provided the background...some questions:
1. I'm theorizing that adding a small ground plane, maybe a 6" metal plate, to the exterior antenna will have a benefit on its communicating with the city. But...will that affect it's communication to the 1st floor?
2. I tried a small 3' antenna for the external - it didn't talk to the 1st floor. My assumption is that the radiation pattern of the 3' antenna is too flat compared to the 8". Probably correct?
3. The antennas are all vertical...hence I assume my network is "vertical polarity". What would be the likely change if I were to angle the 1st floor antenna - so it was closer to perpendicular to the roof location?
I'm still looking for a good application reference for the novice.
