doctordave
- Joined
- Jan 2, 2003
- Messages
- 1,562
Folks,
I made a ground-plane antenna, cut for 39 MHZ, out of 3/8" copper piping material....has one vertical element and 3 horizontal ground plane elements - each is 6' in length. Wondering if there's anything I should do to tweak this further.....also, how much will the resonance at 39MHZ be thrown off if I also add vertical elements for VHF-Hi and 800 range reception (figuring 3.3'ish and 18'ish inch elements).
And yet another question......I was limited to placing this in my attic.....but only 3 feet below the antenna are household 120 VAC wires(on the floor of the attic)......is it possible to somehow shield those electric wires and thereby get rid of some of the noice in my system??
Thanks much.
Dave
Thanks much.
Dave
