All Band Fire Stik Antenna Mount?
shajoe44
North Augusta, SC
I have a 4 ft all band Fire Stik Antenna. I am looking for a mount with the proper coax to try with my scanner. I need a male BNC connector. I'm just trying to experiment with the reception compared to the other all band antenna i am using now. Thanks.
Blackswan73
Central Indiana
Use standard rg8x or RG58 and use PL259 connectors. Then use a short say 2’ LMR400 jumper with the Pl259 or SO239 on one end Ann BNC on the other end
majoco
Stirrer
New Zealand
So which antenna have you really got. There's lots of Firestik antennas that are 4ft long including CB, 10metres and 2metres - none of which seem to be called 'all band' - and they all fit the standard Firestick mount 3/8" 24tpi base which I suspect will have a so259 female on the other side.
KevinC
Other
Super Moderator
Home
I'm guessing this one...
MOBILE SCANNER ANTENNAS
