Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum
California Radio Discussion Forum - Forum for discussing Radio Information in the State of California.
  #21 (permalink)
Old 01-01-2016, 5:24 PM
Dragon911's Avatar
Air21 appears to be based out of MCC and seems to usually be deployed mostly at night.
Some pix (check out the back seat view!) :
  #22 (permalink)
Old 01-13-2016, 1:56 AM
Originally Posted by rananthony04 View Post
FWIW, I hear H-50 in the Orange/LA County area.
Yes. I used to hear H50 all the time in the San Fernando Valley. Dont hear them as much anymore.
  #23 (permalink)
Old 01-13-2016, 2:29 AM
Aero125's Avatar
CHP air 50 is a LongRanger N4014Z based at Fullerton Apt. It makes it's way around LA/OC regularly.
  #24 (permalink)
Old 01-13-2016, 10:00 PM
Do you guys hear them on the blues or on local bases?
You be steppin....I be stomping.
  #25 (permalink)
Old 01-15-2016, 9:44 PM
Dragon911's Avatar
It depends on what they are doing/working. I used to hear the fixed wings use the blue for airborne speed enforcement to co-ordinate with the cars on the ground.
  #26 (permalink)
Old 08-31-2016, 4:25 AM
kma371's Avatar
Global DB Admin
Seeing N140HP (GA8) flying around Sac area. It's not on our list. I assume it's AIR 23 out of Valley Division, but I can't confirm.
EDIT: Looks like it actually took off from Napa, so maybe it's AIR 31?
By the way the list in the very first post is the most current.
  #27 (permalink)
Old 08-31-2016, 10:30 AM
Air37's Avatar
130HP changed its tail number to 140HP since the aircraft that had before it crashed.
  #28 (permalink)
Old 08-31-2016, 11:16 AM
MrAntsy's Avatar
Old pictures of H-80 N109HP from a trip to Toro Peak attached (if I did it right)...
  #29 (permalink)
Old 09-03-2016, 5:10 PM
kma371's Avatar
Global DB Admin
So just to confirm, 130HP is now 140HP which is Air 21, correct?
  #30 (permalink)
Old 01-14-2017, 1:00 AM
kma371's Avatar
Global DB Admin
N981HP and N982HP are new CHP helicopters, likely based out of Golden Gate division (based on their flight paths), but unable to pin down their callsigns. I think there is one more out there, but I don't recall the tail number as it's not currently in the air.
  #31 (permalink)
Old 01-14-2017, 9:04 AM
Air37's Avatar
Yes, 981 is the new H-30 and 982 is H-32. 983 is almost done and will be going to Paso. 314 and 341 went south and you should see them in Fullerton
Old post but this isn't one of our GA8s. I believe it was built by Summit Aviation and is in use on the east coast.
  #32 (permalink)
Old 01-14-2017, 1:35 PM
kma371's Avatar
Global DB Admin
Yes, 981 is the new H-30 and 982 is H-32. 983 is almost done and will be going to Paso. 314 and 341 went south and you should see them in Fullerton.
Thread updated.
Do you happen to have/know the callsigns for the Fullerton and Paso birds?
  #33 (permalink)
Old 01-14-2017, 2:04 PM
Air37's Avatar
Thread updated.
Paso/Coastal Div is H-70 and I'm not sure what H numbers 314/341 is.
  #34 (permalink)
Old 01-16-2017, 10:28 PM
kma371's Avatar
Global DB Admin
Another one is N979HP
  #35 (permalink)
Old 01-16-2017, 10:31 PM
Air37's Avatar
979 is currently based out of HQ as a glass cockpit transition trainer and will be going to Redding once 983 is delivered to Paso
  #36 (permalink)
Old 01-18-2017, 3:45 PM
Air37's Avatar
Correction... 976 is out of HQ and going to Redding and 979 is currently in Paso and also going to Redding once 983 is delivered.
  #37 (permalink)
Old 02-11-2017, 9:14 AM
Default Southern Division
Do you know if there are any air-units assigned to Southern Division (like Los Angeles)? I can't seem to find any information on their air units
  #38 (permalink)
Old 02-19-2017, 7:09 PM
Woah! Haven't logged in a while. Good to see my OP has indeed been popular. A quick update; N6197N is now showing that it's registered to a Pleasant Aviation in TX. So, no longer owned by the CHP. I guess it should be removed from the list. On that note, Anyone know where N518HP, is based out of now? It's not in Fullerton anymore. I went to their Air Show and it wasn't there. Their pilot said it was moved up north a long time ago, he didn't specify where though. It's definitely still flying for them though. Still registered and all.
  #39 (permalink)
Old 04-16-2017, 5:20 PM
Nice info... thanks
  #40 (permalink)
Old 04-16-2017, 5:25 PM
Most likely Auburn
