Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum
California Radio Discussion Forum - Forum for discussing Radio Information in the State of California.
  #21 (permalink)
Old 11-01-2017, 3:46 AM
gvranchosbill's Avatar
I have been in search mode covering 162 mhz - 174 mhz and the only usfs comms i received at all were on
164.1250 mhz/156.7 El Dorado N.F. Service Net (Still Active)
164.1875 mhz/Input Humboldt-Toiyabe N.F. Forest Net (Bridgeport District)
168.1750 mhz/094.8 hz Tahoe N.F. Fire Net
169.9000 mhz/094.8 hz Tahoe N.F. Admin Net
169.8750 mhz/CSQ hz Humboldt-Toiyabe Forest Net
170.4750 mhz/Input Humboldt-Toiyabe Forest Net
170.5500 mhz/156.7 hz Plumas N.F. Forest Net
170.5250 mhz/CSQ hz Humboldt-Toiyabe N.F. Forest Net (Bridgeport District)
172.3250 mhz/156.7 hz El Dorado N.F. Admin Net
all day on October 31 2017.
The traffic was routine weather and radio checks on HTNF frequencies.
171.3875 mhz doesnt ring a bell with me what is, or was this frequency?
Im monitoring close the 169.9750 mhz and 171.4250 mhz freqs also since leviathan pk frequency is non-operational currently.
I got some odd car/car traffic that was very local but brief comms regarding directions to a location nearby and im guessing it may had been the radio techs going to sierra front dispatch (minden) 166.9500 mhz/CSQ analog, this frequency has never heard any comms on it in the 20 + years at my location.
gvranchosbill
Uniden BCT15(1), BR330T(1), Radio Shack Pro-163(2), Feindaxin FD-150(8),FD-450(8),
Puxing PX777(2), PX888(2), Weierwei VEV-868(1), Motorola Maxtrac(2), Motorola GP-300(6)
  #22 (permalink)
Old 11-01-2017, 5:42 AM
171.3875 is an old Stanislaus NF Input. I figured that Iíd venture a guess, being that 170.525 was originally
allocated to the Inyo NF, at least in theory, I believe, and now is being used for the Humboldt-Toiyabe, Bridgeport RD. 171.3875 also used to be an input for the Modoc NF.
WB
  #23 (permalink)
Old 11-01-2017, 10:17 AM
Maybe also try 170.575. Iíve noticed that in other situations, they have taken old inputs from adjacent Forests and used them as outputs for other forests. I donít know if that is the case in this situation, only conjecture. Thatís why I mentioned the other Frequencies.
WB
  #24 (permalink)
Old 11-03-2017, 11:47 PM
Back to 169.875 for an Output. For example, fairly recently the Salmon-Challis National Forest South Net
was changed from 169.875 to 169.925.
WB
  #25 (permalink)
Old 11-04-2017, 12:13 AM
I wiil continue to search federal vhf highband however the weather has begun to change and i assume that mtn top work will be discontinued till next year.
All below were used on 2013 ray may fire.
Do you know if these will change? they fall in repeater Input Range
163.1000 U.S.Govt Common-2(Simplex)
163.7125 NIFC Intra-Crew Net(Simplex)
Outputs on inputs, inputs on outputs.
166.2750 NIFC Command-26 Portable Repeater Tone-3/169.6500 Input
167.1000 NIFC Command-5 Portable Repeater Tone-5/169.7500 Input
168.0750 NIFC Command-3 Portable Repeater Tone-3/170.4250 Input
Repeater Output Range
170.0500 HTF MarkleevilleTac Car/Car(Simplex)
171.0500 BLM-Silver State Hotshots Tone-11(Simplex)
171.6750 BLM-SOA/NV Tone-11(Simplex)
173.6250 NIFC Tertiary-I.A. (Simplex)
I assume these are ok and wont change???
166.5500 NIFC Tac-4(Simplex)
167.1125 NIFC Tac-5(Simplex)
167.1375 NIFC Primary-I.A.(Simplex)
168.0500 NIFC Tac-1(Simplex)
168.2000 NIFC Tac-2(Simplex)
168.2375 NIFC Tac-6(Simplex)
168.3500 U.S. Govt Common-1(Simplex)
168.4275 BLM Sierra Front Flight Following Tone-11(Simplex)
168.5500 NIFC Incident Call Up Sierra Front Tone-1(Simplex)
168.6000 NIFC Tac-3(Simplex)
168.6125 NIFC Secondary-I.A.(Simplex)
168.6250 NIFC Aircraft Guard Sierra Front Tone-1(Simplex)
168.6500 NIFC National Flight Following Sierra Front Tone-1(Simplex)
168.6625 Region-5 Project Net(Simplex)
170.4125 NIFC Command-10 Portable Repeater Tone-9/165.9625 Input
There were many simplex comms on the repeater input range during the ray may fire and i have that list but i dont know who they were they may had been more hotshot crews on there own tac channels .
The list.
162.2000 Simplex CSQ
162.9000 Simplex CSQ
163.0250 Simplex CSQ
164.1500 Simplex CSQ
164.3750 Simplex CSQ
164.7250 Simplex 082.5 Hz
165.5125 Simplex 192.8 Hz
Air/Ground freqs i wont ask there are so many and seem to change often.
Also will the USFS Forest Nets and BLM local simplex channels on repeater outputs change as well?
I understand the reasons to standardize and it will take some time i imagine.
gvranchosbill
  #26 (permalink)
Old 11-04-2017, 1:06 AM
Iím not sure exactly what will change. It seems like there are quite a few exceptions to the rules of the
new NTIA guidelines. You may be correct about the weather change. If there is to be any additional Frequency changes, they may not be until Spring.
WB
  #27 (permalink)
Old 11-04-2017, 1:13 AM
Frequency Input License Type Tone Alpha Tag Description Mode Tag
172.27500 RM SalNF Disp 1 Dispatch FMN Federal
168.75000 168.15000 RM SalNF Disp 2 Dispatch - Spot Mountain FMN Federal
171.52500 M SalNF SalTac Tac 1 FMN Federal
168.20000 M CSQ SalNF Tac2 Tac 2 FMN Federal
168.60000 M CSQ SalNF Tac3 Tac 3 FMN Federal
166.76250 BM CSQ SalNF A/G 1 Air-Ground 1(23) FMN Federal
167.60000 BM CSQ SalNF A/G 2 Air-Ground 2(43) FMN Federal
This is what the database shows may need updating?
I noticed a lot of database info needs updating as i look at recently for other areas.
I didnt look at wiki pages that info that i have seen seems more detailed and up to date so far.
gvranchosbill
  #28 (permalink)
Old 11-06-2017, 11:09 AM
Not sure exactly. All I really know is that one of their nets was changed from 169.875 fairly recently. The
Humboldt-Toiyabe is the only National Forest in the West, at least, that is still using 169.875, that I am aware
of. 169.875 used to be in use in Forest Service Regions 2,3,4,5 and 6, and has either been already phased out in the frequency conversion, or is in the process of being phased out. That is why I am questioning whether or not they will continue using 169.875 as an Output on the Humboldt-Toiyabe.
WB
  #29 (permalink)
Old 11-06-2017, 11:12 AM
Even though technically, 169.875 meets the new NTIA standard to be an Output, it is in the range; it just
seems like the Forest Service is phasing it out. At least for Main Net Outputs in the West?
WB
  #30 (permalink)
Old 12-27-2017, 7:49 PM
https://www.recordcourier.com/news/l...k-transmitter/
This article was in Record Courier local newspaper for Minden Gardnerville,Nv
Dated December 22 2017
Jobs Pk is 10,633 Feet and overlooks Toiyabe(HTNF R-4) and Lake Tahoe Basin (TMU R-5)
Bordered by Douglas County,NV Alpine County,CA El Dorado County,CA
I suppose we will know the status on new freqs soon and i can look right out my window directly
at Jobs Pk and if approved i will be able to watch the airlifting of the repeater to the location
Forest Service proposes Jobs Peak transmitter
December 22, 2017
Climbing Jobs Peak is a rite of passage for Carson Valley residents. If a U.S. Forest Service proposal is approved, those who've summited will also get to visit a new transmitter.
The Forest Service is conducting an environmental analysis to erect a radio repeater on the landmark peak to improve radio communciations.
According to a Dec. 7 letter to stakeholders, the repeater, shelter, solar panels and a 20-foot antenna would be helicoptered to the top of the mountain.
The shelter will be 5-feet square, according to the Forest Service.
The deadline for responses under the 30-day public comment period is Jan. 8.
"This scoping period is intended to provide those interested in or affected by this proposal an opportunity to make their concerns known prior to a decision being made by the responsible official," District Ranger Irene Davidson said in her letter.
According to the Forest Service, there are areas in the Carson Ranger District that do not have radio coverage. Radio specialists determined that Jobs Peak would be the best place for improved radio coverage. Solar panels would be placed next to the shelter to power the transmitter. No digging or other ground disturbance would be required.
Officials are calling the transmitter use minor, saying there is no circumstances warranting more analysis or documentation in an environmental analysis or an environmental impact statement.
Comments may be sent to elnoesser@fs.fed.us or by telephone by calling 760-873-2449.
gvranchosbill
  #31 (permalink)
Old 12-28-2017, 12:40 AM
This is very interesting. Any luck on possibilities for the new frequencies for the Carson Ranger District?
WB
  #32 (permalink)
Old 12-28-2017, 1:00 AM
I guess another question would be; are you still copying any traffic on 169.875 or 169.975 on Leviathan?
WB
  #33 (permalink)
Old 01-10-2018, 3:49 PM
Copied traffic on the HTF Carson District Net this afternoon. I did not get the details, because I was in the other room. However, it sounds like they are getting ready to switch over to the new frequency pair for the Carson RD. Still unable to determine what the new frequency pairs are at this time.
WB
  #34 (permalink)
Old 01-21-2018, 5:26 PM
Last week, radio techs doing checks on 169.875: Slide, Peavine, and Rawe Peak. Still no indication of any new frequency, or what it may be.
WB
  #35 (permalink)
Old 03-16-2018, 10:23 AM
I noticed that Leviathan Peak, which covers the Carson-Iceberg Wilderness, Markleeville, and Antelope Valley areas of Eastern California, as well as the Carson Valley areas of Western Nevada is now on 172.275 MHz. Also, an indication that the rest of the Carson RD on the Humboldt-Toiyabe will remain on 169.875 for at least the 2018 Fire season. Iím not sure if the rest of the repeaters on the HTF, Carson RD will be switched to 172.275, or if a different frequency will be used, as Leviathan has always been on a separate frequency than the rest of the Forest for some reason.
WB
  #36 (permalink)
Old 04-08-2018, 10:02 AM
swylie's Avatar
Zone 1 - RENO SIERRA FRONT INTERAGENCY DISPATCH CENTER “MINDEN” ZONE NV03
CARSON RANGER DISTRICT 1 - DFMO WILDE
NOTE: THIS ZONE USES TONE PICK LIST. TONES ARE INDICATED IN PARENTHESES.
CHANNEL CHANNEL DESCRIPTION RX RX-CG TX TX-CG BW FCN
1 169.8750 0.0 170.4750 110.9 N CMD
2 158.7450 0.0 159.3900 123.0 N CMD
3 158.8950 0.0 156.0750 131.8 N CMD
4 169.9875 146.2 162.2375 136.5 N CMD
5 168.1750 0.0 170.6000 146.2 N CMD
6 168.2000 0.0 168.2000 156.7 N TAC
7
TOI 1-4, 9
TM 4 10-12
NDF 1-8
BLM 29 -32
TNF 167
NIFC TAC 2
158.8800 0.0 158.8800 167.9 N TAC
8 158.9400 0.0 158.9400 103.5 N TAC
9 154.2800 0.0 154.2800 100.0 N TAC
10 154.2650 0.0 154.2650 107.2 N TAC
11 154.2950 0.0 154.2950 118.8 N TAC
12 171.6750 114.8 171.6750 127.3 N TAC
13 168.3125 0.0 168.3125 114.8 N AIR
14 166.8750 0.0 166.8750 173.8 N AIR
15 167.5000 0.0 167.5000 186.2 N AIR
16
TM TAC 1
TM TAC 2
VFIRE 21
VFIRE 22
VFIRE 23
NV SOAI
SEC AG8
163.7125 0.0 163.7125 203.5 N TAC
HTNF SLIDE (1), PEAVINE (2), HAWKINS (3), RAWE (4), McCLELLAN (9)
TMFD RFD VIRGINIA PK (4), RFD PEAVINE (11), RFD SLIDE (12)
NDF PINENUT (4), NDF EAGLE (5), NDF PEAVINE (2), NDF MCCLELLAN (1)
BLM LOCAL (USE TA), BLM FAIRVIEW (13), BLM FT SAGE (14), BLM MCCLELLAN (15),BLM VIRGINIA PK (16) SQUAW (1),
BABBIT (6), ROSE (7) THESE ARE DISPATCHED OUT OF GRASS VALLEY CENTER
NIFC NATIONAL INCIDENT TACTICAL CHANNEL - LOCAL-SIMPLEX (MOBILES & HANDHELDS ONLY) TAHOE NF TMFPD
RENO GOLD - SIMPLEX
TRUCKEE MEADOWS TAC II ON TX - SIMPLEX
MUTUAL AID - NDEM-SIMPLEX
IMUTUAL AID - NDEM-SIMPLEX
BLM SCENE OF ACTION TONE 13 ON TX
INTERAGENCY SIERRA FRONT NV03 PRIMARY AG 51
INTERAGENCY SIERRA FRONT NV03 SECONDARY AG 08
INTERAGENCY CALIFORNIA R5 CA02 PRI AG 14
FS HTNF FIRE TAC USE ONLY - SIMPLEX
Zone 2 - CARSON SIERRA FRONT INTERAGENCY DISPATCH CENTER “MINDEN” ZONE NV03
2 172.2750 0.0 164.5000 123.0 N CMD
3 169.9875 146.2 162.2375 131.8 N CMD
4 158.8950 0.0 156.0750 136.5 N CMD
5 154.4300 0.0 153.8450 146.2 N CMD
6 155.0850 100.0 155.7750 156.7 N CMD
7
TOI 1-4, 9
TOI8 LEV
BLM 29-32
NDF 1-8
CCFD 28
EASTFK 9
168.2000 0.0 168.2000 167.9 N TAC
8 171.6750 114.8 171.6750 103.5 N TAC
9 159.3450 0.0 159.3450 100.0 N TAC
10 154.2800 0.0 154.2800 107.2 N TAC
11 154.2650 0.0 154.2650 071.9 N TAC
12 154.2950 0.0 154.2950 127.3 N TAC
13 154.1450 0.0 154.1450 114.8 N TAC
14 168.3125 0.0 168.3125 173.8 N AIR
15 166.8750 0.0 166.8750 186.2 N AIR
16
NIFCTAC 2
NV SOA
RED1
VFIRE 21
VFIRE 22
VFIRE 23
PRI AG51
167.5000 0.0 167.5000 203.5 N AIR
LOCATION & TONE & REMARKS
R5 AG14
CCFD TAC
SEC AG8
HTNF LEVIATHAN (8)
BLM LOCAL (USE TA),BLM FAIRVIEW (10) BLM MCCLELLAN (15)
NDF MCCLELLAN (1), NDF PEAVINE (2), NDF SNOW VALLEY (3), NDF EAGLE (5),
CCFD COMMAND NET CHANNEL
DOUGLAS COUNTY-EAST FORK FIRE DEPT TONE (9)/ TA FOR LOCAL SIMPLEX
NIFC NATIONAL INCIDENT TACTICAL CHANNEL -SIMPLEX (MOBILES & HANDHELDS ONLY)
SCENE OF ACTION (SOA)- - LOCAL - SIMPLEX
NDF DIRECT - SIMPLEX - LOCAL
CARSON FIRE COMMAND
INTERAGENCY SIERRA FRONT PRIMARY NV03 AG 51
INTERAGENCY CALIFORNIA R5 CA02 AG 14
3 172.3750 156.7 164.9625 131.8 N CMD
4 169.9875 146.2 162.2370 136.5 N CMD
5 158.8950 0.0 156.0750 146.2 N CMD
6 155..0850 100.0 155.7750 156.7 N CMD
7
TOI 1-4, 9
TOI8 LEV
TMU123
BLM 29 -32
NDF 1-8
EASTFK9
153.8000 0.0 154.1000 167.9 N CMD
8 168.2000 0.0 168.2000 103.5 N TAC
9 171.6750 114.8 171.6750 100.0 N TAC
10 159.3450 0.0 159.3450 107.2 N TAC
11 154.2800 0.0 154.2800 114.8 N TAC
12 154.2650 0.0 154.2650 127.3 N TAC
13 154.2950 0.0 154.2950 114.8 N TAC
16
ALPINE10
NIFCTAC2
NV SOA
RED1
VFIRE21
VFIRE22
PRI AG51
R5 AG14
VFIRE23
SEC AG8
FS HTNF SLIDE (1), PEAVINE (2), HAWKINS (3), RAWE (4), McCLELLAN (9)
FS HTNF LEVIATHAN (8)
SNOW (1), EAST (2), SCOUT (3) THESE ARE DISPATCHED OUT OF CAMINO CENTER
ALPINE COUNTY
NDF RED 1 DIRECT - SIMPLEX
  #37 (permalink)
Old 04-08-2018, 10:03 AM
swylie's Avatar
The last entry was copied from their Radio Guide for 2018 and it was a PDF file so it was hard to format.
  #38 (permalink)
Old 07-06-2018, 8:28 PM
Smile Toiyabe N.F. Jobs Pk repeater build starts in july
June 2018 article
https://www.recordcourier.com/news/l...es-up-in-july/
Now would be a good time to work on frequency search.
I can see jobs pk from my location.
gvranchosbill
  #39 (permalink)
Old 07-07-2018, 6:54 PM
Question Toiyabe NF Leviathan Pk repeater question
Do i understand correctly from swylies post that leviathan pk has been changed?
Also it shows TOI8 LEV so is it tone-8 (103.5) or tone-2 (123.0)?
Leviathan Old 169.9750 Frequency CSQ/ 171.4250 Input 103.5 Tone-8
Leviathan New 172.2750 Frequency CSQ/ 164.5000 Input 123.0 Tone-2
gvranchosbill
  #40 (permalink)
Old 07-07-2018, 9:37 PM
Smile
You are correct sir, Leviathan is now 172.275. I recently copied traffic, albeit not very much. Also, to my knowledge, from what I have copied, it is still Tone 8. I believe the reason that Leviathan used to be on 169.975, was that Sierra NF was using 169.875 as an input to one of their nets, and that has been changed also. So, my guess is that they did this to reduce or prevent interference, due to Leviathanís location, relative to the other Humboldt-Toiyabe repeaters, which as you know are still on 169.875, at least up here in Northwestern Nevada.
WB
