Dont have a SWR meter yet
antman157
I dont have access to a SWR meter yet .. Would I be ok hooking up my Maxrad 2700 antenna to my Uniden 510XL CB without any issues?
rescue161
KE4FHH
Hubert, NC
I would not, simply because even a small movement of the antenna, up or down, can cause the SWR to become too high. You never know how much power is being reflected back into the radio unless you have a meter. You'd be taking a chance for sure.
Tulsa
After you have an SWR bridge, make sure your antenna is mounted correctly so that the antenna has a good ground plane to work against. A lot of folks will see a high SWR reading and start wacking awsy at the antenna trying to compensate for the lack of an adequate plane, for the antenna to work against. Just remember the actual antenna is only half the radiating system, the ground plane that it sets on is the other. A ground plane is different from a ground wire.
