has anyone ever used a workman b100 antenna i found alot of them on ebay there only 39" ineed a good base antenna and do i need a antenna tuner?
Did you buy this antenna? I am thinking about buying one to. I would like to know if they work OK. My wife does not want a huge antenna on the roof.
WHATS THE MAX MILES THE WORKMAN B1OO CAN TRANSIEVE ?
It's interesting that according to Workman, this antenna should use specific lengths of coaxial cable. I think they also recommend 50 feet of coaxial cable for optimal performance.ok so the less cable the better okie dokie..
I'll double check the coax. The mast does extend beyond the bracket though. I have the antenna mounted on a "yard arm" about 20" off to the side of the mast and a scanner antenna at the top of the mast (I do disconnect the scanner from the antenna when transmitting on the CB).
I should not have said dead silent, there is a noticeable increase in noise when I connect the antenna to the radio and I have picked up some signals. Not nearly as much as I get when I use the radio in my truck with a just a little mag-mount. Last night there chatter on several channels (out in the truck), but nothing came on on the base. I have swapped in a known, good working, radio (the one from the truck) just to be sure the one I was using in the house wasn't the issue. SWR is around 2:1 at it's worse and 1.5:1 at the best.
I'm going to go ahead an pull it down (since I need to check the coax anyway) and remount it on it's own mast (a 10' piece of galvanized pipe) and ensure it is at the top of the mast.
