Get yourself an astron 7amp 12 volt Fully Regulated power supply ,hook the red wire to the red terminal and the black wire to the black terminal ,turn the power supply on and you are done.I would put the antenna outside on top of a road sign or other metal.Keep the antenna away from structures or you will have reflected transmit power.If you have the cash,buy a Antron base antenna ,put on pole on the roof with chimney straps.
Keep the antenna away from any and all wires that are attached to your home.Copper electronics is the cb guys friend.
