Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > CB Radio Forum
CB Radio Forum - Discussions regarding Citizens Band Radio (CB)
Old 08-15-2012, 8:26 PM
wpwx694's Avatar
Default the best coax cable base station antenna?
which is better RG 58a/u, rg8u or rg 8x for cb ssb radio base
I have Solarcon A-99 Antenna and a Cobra 148GTL
Old 08-15-2012, 8:49 PM
w2xq's Avatar
Mentor
Of those choices, RG-8U. Good connectors and waterproofing the antenna connection would be equally important. HTH.
Tom - W2XQ - w2xq.com - 3101743
Old 08-15-2012, 9:15 PM
wpwx694's Avatar
what about RG6U
Old 08-15-2012, 9:33 PM
Originally Posted by leawoodcops View Post
what about RG6U
That would depend on what the design of the antenna was. Most antennas are made around a 50 Ohm impedance and not the 75 Ohms that the RG6 cable is built for. If it is only for receiving, your probably OK. But for transmitting, your not going to be able to get a low SWR.
Jim
Old 08-15-2012, 10:59 PM
wpwx694's Avatar
is RG213 or LMR-400 good
Old 08-15-2012, 11:18 PM
n5ims's Avatar
The missing piece of information we need is how long of a run are you going to have. The answer for a 25 foot run may not be the same as one that's 250 feet long.
RG-213 is in the RG-8 family and is a bit better quality and somewhat lower loss than standard RG-8 (much better than some low quality junk RG-8 some folks may be selling). Check the specs on your coax. What you want are high sheld coverage (100% or close is best, 85% is crap), low loss (search for "Coax Loss Calculator" to compare the values) although at CB frequencies the differences will be minor, easy to find and attach connectors of the type you need (generally PL-259 for CBs), then size and flexability (read ease of installation) although better types will be the larger and lesser types smaller.
For a standard CB install my choices would be (best to worst) for the given choices:
1. RG-213
2. RG-8 (quality stuff, not some cheapo no-name brand or store brand that buys from whomever sells for less at the time).
3. RG-8x
4. RG-58 (quality stuff, not some cheapo no-name brand or store brand that buys from whomever sells for less at the time).
5. RG-6 (as was indicated you'll have higher SWR and connectors may be harder to find/attach)
Old 08-15-2012, 11:37 PM
wpwx694's Avatar
it will be 15 or 20 foot
Old 08-15-2012, 11:56 PM
n5ims's Avatar
At that length nearly any standard 50 ohm coax should work fine (read that quality coax, not cheap junk coax though!). This assumes you'll be running legal power (doesn't everybody?). If you do run a "kicker" you'll need to consider the power handling capabilities of your coax as well. Chances are the RG-8 series or even RG-8x will easily handle the extra power, but RG-58 may or may not. Check the specs of what you're getting to be sure.
Old 08-16-2012, 12:40 AM
wpwx694's Avatar
legal power and thanks everyone
Old 08-16-2012, 11:23 PM
wpwx694's Avatar
I went with RG213
Old 08-17-2012, 9:44 AM
wpwx694's Avatar
here it is
Old 08-17-2012, 4:55 PM
Rt169Radio's Avatar
Looks quite good,have you tried it for scanning?
Old 08-17-2012, 4:57 PM
wpwx694's Avatar
thanks
Old 08-17-2012, 5:09 PM
thanks
The next question is did you ground the antenna support?
Jim
Old 08-17-2012, 5:49 PM
wpwx694's Avatar
I grounded the antenna with a ground rod
Old 08-17-2012, 6:59 PM
wpwx694's Avatar
how do I waterproofing the antenna connection?
do I just put electrical tape around the connector
Old 08-17-2012, 7:29 PM
GTR8000's Avatar
Troublemaker
Get a roll of 3M rubber splicing tape. Wrap all outdoor connections with the tape a few inches past the connectors, then wrap over that with some quality electrical tape like 3M Super 33+ vinyl.
http://amzn.com/B00004WCCK
Old 08-17-2012, 10:06 PM
wpwx694's Avatar
will one day of rain mess it, we have a 50 chance of rain
Old 08-17-2012, 11:23 PM
prcguy's Avatar
Did you connect the ground rod to your main house ground? See NEC 810.
prcguy
Old 08-18-2012, 12:40 AM
wpwx694's Avatar
i have rod in the ground
