Please don't judge me after reading about my set up.
I'm using an indoor antenna called a Workman b100 Saturn antenna.
My power supply is a pyramind 6 amp with 8 amp surge
My mic is a d104m6b power mic..Astatic.
I recently purchased a MFJ 929 automatic antenna tuner, so I could achieve a good SWR.
(Please no lectures on how to tune an antenna without an antenna matcher. Please no lectures on how there is still lost signal. I know that.)
I had been using a Maco 91 antenna tuner, and it worked so so.
But I wanted something easier, so I upgraded.
I connected the MFJ 929 as instructed by the manual.
A perfect match is now achieved.
BUT
One problem.
Now I'm receiving shocks through my d104me6b power mic when I transmit!
Without any wise guy remarks, or wise guy solutions..ie..get an outdoor antenna and tune it...
can someone explain what's going on with the shocks? Can someone suggest a way to remove them?
Also the MFJ 929 has a screw nut thing on the back that says ground.
Is that for me to run a ground wire from the antenna to the ground screw nut thing?
BUT
One problem.
