I'll present my system specifications before my question(s):
Components:
Radio Shack Adjustable 48" Fiberglass Whip Element for CB Antenna (PN: 21-974)
Radio Shack Chrome-Plated Spring CB Antenna Mount (PN: 21-1118)
Radio Shack Mobile CB Antenna Ball Mount Base (PN: 21-1115)
Installation:
The ball mount is affixed near the rear corner of a pickup truck bed, on the driver's side, approximately 3.5" below the rim of the bed walls. Approximately 10' of coaxial cable is routed through the driver's side pickup bed wall, then into the cab.
Measurements:
With the antenna at its lowest position in the compression coupling, on top of the 4.13" spring, I have a 51.5" overall length (or just about 1/8λ physical length, end-to-end). The ball mount adds another ~2", making it slightly longer than ideal for the center of the CB band (27.185 MHz), or so it would seem.
The SWR readings also lend credence to the theory that the antenna is currently tuned to a much lower frequency than 27.185 MHz (ch. 19):
26.965 MHz (ch. 1): ~1.1
27.185 MHz (ch. 19): ~1.5
27.405 MHz (ch. 40): ~2.4
Questions:
Before I take a hack saw or Dremel to this antenna, to shorten it, I need to know more about the antenna. Radio Shack has not published sufficient specifications, other than the fact that it is about 48" long. So, is this supposed to be part of a 1/8λ antenna, or is there a loading coil somewhere within, making it a 1/4λ (or other wave fraction)?
Second, if there is a loading coil, where is it? I don't want to go lopping that off...
Third, if you don't *know* the answers to my questions, what would be your best guess?
Thanks,
Mike.
Components:
Installation:
Measurements:
Questions:
Thanks,
Mike.
