Hello W1018:
I would think NO to the low pass filter. The Low Pass filter will significantly reduce multiples (harmonics) of your transmit frequency or unwanted spurs above 30 MHz, which is a good thing to have.
But it sounds like your experiencing RF Overload condition, that is a strong and near by RF Field of Energy getting into your equipment there. The low pass filter will not help in this case.
You can move the antenna up or even farther away from your location which will help but may not be the cure. Its possible to install RF Toroids or snap on Toroids from Radio Shack over the input and even output wiring. Making sure the antenna mast is grounded is a good thing.
The ARRL sells a book on RFI and it has a bunch of great info in there.
I have a FM Broadcast Antenna mounted on my CB Antenna Mast about 3 feet from the bottom of the CB Antenna, and yeah I get RF Overload into my FM Stereo Radio, but the FM Antenna Coax I rolled into a coil of about 10 turns on about a 10 inch diameter, and installed the Radio Shack snap on Toroids, over the FM Antenna Coax and RF Overload interference is gone.
Theres plenty of articles on RFI on the net that can help out.
Good luck, please let us know how you make out......
Jay in the Mojave
Hello,
Every time I key up and speak into the mic it gets transmitted into my equalizer and mixer when it isn't even plugged in at the input, and sounds terrible. I would like to be able to incorporate these two items into my base setup but am having no luck. Would this be something that a low pass filter would cure?
