Squelch Problem
ScanMonk21
Mystic, CT
Hey guys,
I've had my Cobra 29 wx nw st for awhile now and just recently the squelch doesn't seem to work. It has to be moved all the way to the right and even with it fully closed I still hear static. The rf gain is the only thing to completely cut the noise. I can still transmit because my friend can still hear me with his scanner. I can barely hear transmissions though.
Thank you for the help
JayMojave
Mojave Ca
Hello SM21: Try removing the antenna connector, and see if you still have a Squelch problem.
If the problem is still there you have a radio problem, if the squelch then works you be receiving some sort of noise.
You didn't tell us too much about your radio set up.
Jay in the Mojave
ScanMonk21
Mystic, CT
Hello I actually resolved the problem. It was my location of my car haha. I was near a transformer. But I'm running a K30 antenna magnet mount antenna. Its a foot away from my scanner antenna. At the time my SWR readings were perfect. Thank you for your response
