TheDude1969
- Joined
- May 22, 2013
- Messages
- 24
I'm within city limits so no ugly antenna or tower.
I'd like to do this w/ $0 using 102" stainless whip and parts around house.
Since I'm in a valley my thought is to use my TV antenna as mount location, highest most inconspicuous location, base of whip approx 20'-25' high. <--- I don't mind if that causes interference w/ TV signal.
Question is, would the TV antenna act as my ground plain (I don't know if its grounded, hoping you guys do?), or should I insulate the mount and put rubber ducky below for a vertical dipole? Or will all this mess of metal throw my SWR off so bad I'd be better installing it in attic?
I've not tried anything yet, I'm only assuming highest point is best since truck CB won't reach very far.
Thanks for your help!
