unit928
hi everyone I just put my imax 2000 up but I could only put it up aginst the house for now it is not up very high the bottom of the antenna is only 2 feet off the roof I would say its up about 18 feet total without a ground. I have a great swr less than 1.1 on ch 40 and 1.2 on ch 1 the problem im having is my galaxy Saturn wont talk very far at all im a skip talker, and know all about radio wave propagations. I have made a couple local contacts with truckers on 19 but when I go to ch 38 lsb I can't get out at all when a friend of mine a couple streets over is working Jamaica, uk, and all over the states I am planning on putting it up on the roof about 30 feet off the ground mounted on a 10 foot pole off the roof, and ground the antenna this weekend. do you think that the antenna not being up high enough is what's causing this?? as I am in kind of a small mud hole I have a huge barn beside me, and a two story house as well I looked , and the barn roof is higher than the tip of the imax 2000 thank you for your help with this. ben "unit 928"
