Texas ranger tr696f led lights
darticus
Sparta, New Jersey
TEXAS RANGER TR696F LED LIGHTS
I have heard of some instances of frequency display leds that make up the numbers flicker. Is this a common problem with Texas Ranger CB's? Does anyone know what would cause this in a radio that is 10 years old Not used or little but some flicker than full bright perfect. Again the flicker is only one segment of the 6 digit number. What would be the fix??? Thank for your input Ron
rescue161
KE4FHH
Hubert, NC
Cold solder joints is a big problem. Also, cheap LED segments that are failing or have already failed. You should be able to check with a meter or a scope to see if there are any voltage differences. If a scope shows no variations, then it is more likely the cold solder joints or bad LED segments.
