Dawn
This isn't the best time with the holidays approaching, but I've really been contemplating it over the past several months since getting back on 10FM with a commercial mobile programmed to a few simplex channels and two distant repeaters/remote bases. I've weighed the pros and cons of moving a CB up above 28.5. Figuring the cost and limitations and either having to spend a small fortune for crystals that from my inquiries are now horribly expensive unless ordered in batches, I'd best opt for an old '858 chassis and add bcd switches for the least expensive option or going binary with an 8719 is going to add quite a bit too in time and modifications. Not worth fixing up an old uniden chassis that's 35 years old with unobtainium parts or an old or revived cobra chassis or clone.
Other routes ultimately will end up costing at least $75 over the cost of a used unit that most likely will require repair,alignment, and crystals. Pursuing similar units to the optima like a magnum or other unit that doesn't operate with channels and programmable divider bank switching like the rangers that cover the same area doesn't make much sense when this unit is of much higher quality and the firmware is more amateur oriented. Maybe not a cb/Freebander's cup of tea, but would be worth it if it delivers. The price is either comparable or about 50 bucks more then the cheapest solution in a magnum 257.
I hope it turns out to be what it's touted as.
