Turner
CyberWarrior
Ft Lauderdale FL
Ok I admit defeat.
No matter what,I am unable to find a wiring scheme for a Super Sidekick.
to be used on an Bearcat 980.
Unfortunately I can't even call the maker Turner,since they sunk 1979
Weaksignal
CM89
Wiring diagram for the Super Sidekick and +3...
N4ZHM
Waynesville, NC
This is what I found. Hope it helps
CyberWarrior
Ft Lauderdale FL
My only fear is,I might blow something experiment in the wiring.
What I really need is,directions,the turner was wired for a DX 959 and it worked great,
if only I could remember the wiring.
QwKiE
Warren, Michigan
I have heard that the 980 comes with a 4 pin jumper wire to convert to a 4 wire mic easier do you have 1 of them in the box?
CyberWarrior
Ft Lauderdale FL
The adapter is a 6 to 4 pin.
I have a D-104 that is wired for 959 DX,with the adaptor it works fine.
Tried to duplicate wiring for the turner mike,and it will not work
gewecke
Banned
Illinois
I'm getting danger close,to putting this radio in the garbage !!!
Somehow,I can't seem to be able to find the right wiring for the Turner !
Why not just be happy with the stock mic? If its that much of an issue then maybe Uniden never intended alternate mics to be used ... after all how much transmitted audio do you really need. :roll: 73, n9zas
CyberWarrior
Ft Lauderdale FL
I know what you are saying,is just that I know there is a wiring for this mic.
I have been to other forums and they get to use,a +3 on this radio_Only problem is,they do not post the wiring order.
CyberWarrior
Ft Lauderdale FL
Ok guys I have it- 1-White 2-Shield - 3 Black- 4 Red Works fine using the adapter cable.
I only have one problem left: How to get rid of the squealing,I think the SS is going bad.
gewecke
Banned
Illinois
. ...Or stay with the stock mic so you don't risk snuffing a part? :roll: 73, n9zas
