Was reading an article online about base stations and home made antennas, swr, and COAX LENGTH. There it stated that if you needed 50' of coax to run from antenna to transmitter, use 55' instead... if you need to add a meter or another component, the shortest to use would be 6' 9' or 12'... but in order to maximize the resonance of your set up.. you would need to trim from your main line whatever length you added for your accessory. Says that if you need 100'... use 110'...... need 10'? use 11' of coax... catch the multiple of 11? I have read through a lot of threads and have never really heard this before... sounds legit since our cb wavelength is 11 meters... Is it true that from ant connection to transceiver, if kept in multiples of 11, (11-22-33-44-55-66-77-etc it will make for a more efficient setup? Actually I found the thread halfway down here: RadioMods coax length page (um can we post links in here?) hope so if not please edit and I won't ever never do it again..OR.. if not too long I can post the info:-------------------------------------------------------------------------------------------------------------------------------------------------------------------
Any person who says that, "coax length has nothing to do with SWR's" has no knowledge or understanding of broadcasting. I have been in commercial and private radio broadcasting for 25 years, and it's time to dispel the myths about SWR and coax.
Your coax is a vital part of the antenna system and must be tuned for proper operation. Installing an SWR meter at the antenna will measure the SWR's (AT) the antenna, but not the SWR's (OF) the antenna. Even with the meter connected at the antenna, any change in coax type or length, will change the SWR reading on the meter. But it doesn't make sense to check SWR's at the
antenna, because the most important component -THE RADIO- does not see the antenna alone. Your radio is reacting to the entire antenna system, including the coax. Even if you were to set the SWR's at the antenna and make them perfect, the SWR will be different at your radio's end of the coax.
Coax not only has resistance, but it also has capacitance which changes with different lengths. Resistance (Impedance), determines how the transmission line and antenna match the radio's requirement to send the greatest amount of signal to the antenna. But capacitance controls which frequency the antenna is best tuned at. Changing the capacitance of the antenna system, will alter the frequency at which your radio sees the best SWR. Any component you add to the coax line, such as a meter, linear, or
even a coax switch box, changes both the resistance and capacitance. My own radio, a Kenwood TS-570DG, has an SWR meter built in to it.
I also use an external set of meters to keep tabs on my radio's performance. When I check the SWR's on the meter in my radio, It shows a perfect SWR at one frequency. When I check the SWR's with the external meters, they show my best SWR at a
frequency almost one full MHz lower. So which meter is correct? They are both correct. My external meter is reading a perfect SWR at Frequency (X). That is because the resistance and capacitance of the coax and antenna is resonant at frequency (X). But
the meter in my radio is seeing the addition of a meter and a 6 foot coax jumper. This changes the resistance and capacitance of the antenna system that my radio is seeing. It also changes the frequency that the antenna system is now resonant at, so the meter in my radio sees a perfect SWR at frequency (Y) 1 MHz higher. Both meters are telling the truth, but the meter in your radio is the most important one to use for SWR. The meter in your radio is reading the SWR closest to your radio's Final output transistors, and that is more important than the SWR at the coax connector on the back of your external meters.
The following is for use ONLY on 11 meters.
For 11 meter operation, use these figures to set up your antenna and coax.
SORRY! I only know the measurements in FEET. Convert them to meters if you need to for better understanding.
For base stations. Cut your RG-8/U coax in multiples of 11 feet. For example.. if you need 50 feet of coax to reach your antenna, use 55 feet instead. 11 X 5 = 55. Or 11 feet multiplied by 5 multiples equals 55 feet total. If you need 37 feet, use 44 feet instead.
11 X 4 = 44. What ever length you need, go to the next highest length that can be divided evenly by 11. Include all jumper cables in that length. Jumper cables should be cut to 6, 9, or 12 feet. Never less than 6 feet, or more than 12 feet. Example. . . If you need 55 feet of coax to reach your antenna, and you want to add a meter in the line. Use 49 feet of coax from the antenna to your meter, and 6 feet from your meter to your radio. 49 + 6 = 55. If you find that 49 feet is too short from the antenna, then add 11 feet to the coax from the antenna to the meters, making your total length, with jumper cable, 66 feet. 11 X 6 = 66. If later on you decide you want to add another device like a linear in the line, do it this way. Do not just add a jumper for the new device. Where your main coax line from the antenna ends inside your home, cut off 6 feet of the coax, and put antenna connectors on each side that was cut, and add your new equipment at that point. The total length of coax stays the same, and the jumper is also the proper length.
For set up on 11 meters in your automobile, use RG-8X or RG MINI coax. Do the same as I instructed for base station installations, except this time cut your RG-8X to 20 feet minimum. Do not use less than 20 feet. Even if you only need 1/2 of that length, still use 20 feet. The extra coax can be coiled up and put in the trunk or under the seat. If it is possible, try to coil the extra coax as close to the antenna as you can get it. If not, the trunk or under the seat is good. It will not cause any problems. A length shorter than 20 feet can cause RF feedback, because of the antenna being so close to the radio. Also, mobile antennas are usually 1/4 wave or less.
This causes more RF to travel down the coax to your radio. A coax length of 20 feet, and coiling the extra coax under the seat helps to stop some of that RF from feeding back into your radio.
I hope I have helped you better understand SWR and antenna systems.
