Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > CB Radio Forum
CB Radio Forum - Discussions regarding Citizens Band Radio (CB)
  #21 (permalink)
Old 12-17-2016, 4:44 PM
Originally Posted by prcguy View Post
I just measured my 980 at about .1uv sensitivity on 162.55MHz, which is very good. It breaks its internally set squelch around .15uv and will go down to about .1uv before it squelches again, so its hard to pinpoint the exact sensitivity but its more sensitive than most VHF receivers.
prcguy
Thank you.
So is it likely the bearcat or something about the install?
Guys, should I go back to silke ?
KR3LIM
WQYT778
  #22 (permalink)
Old 12-17-2016, 6:21 PM
prcguy's Avatar
If your Yaesu is receiving weather channels on the same antenna the 980 is not then something is wrong with the 980.
prcguy
Originally Posted by Delivers1234 View Post
Thank you.
  #23 (permalink)
Old 12-17-2016, 8:06 PM
mmckenna's Avatar
There are a couple of common issues that can cause weak receive, and they've been covered above, but here's a recap:
1. Antenna - antennas tuned for a different band can provide poor reception. Your CB antenna is tuned for 27MHz, so it's not going to perform well. However, antennas can work well on multiple bands, so all is not lost. Your CB antenna is primarily resonate at 27MHz, although it may work well on others. The longer whip of the CB antenna should work well for VHF, however the loading coil in the base can create an issue.
2. Receiver sensitivity. PRC covered it well above. Sounds like the WX receiver in his radio is working very well (very sensitive), however keep in mind that as the CB radios go down the assembly line, it's up to a human to adjust these receivers to work optimally. Could be yours didn't get quite the attention that PRC's did.
3. Coax/mount issues. Doesn't sound like it's an issue. I think you reported that your CB was working very well.
4. Nearby strong signals. A strong signal close by on a nearby frequency can desensitize the receiver. Probably not the issue, but it's a possibility.
5. Location. You mentioned a carport. If you have a structure between you and the transmitter site at McQueen Ridge (just south of Umunuhm - the one with the old USAF radar station still on top) that could be part of your issue.
I'd suggest trying it in a different location. Move out in the open where you have a clear view to the north.
Sounds like you did all the basic testing I'd have suggested. Could be your CB just doesn't have a sensitive WX receiver in it.
Since you have the Yaesu, it should work well on the weather band. Trying programming the WX frequencies in there. From where I am and at work, I can often get the one from San Francisco. It's weak and scratchy, but it's there.
  #24 (permalink)
Old 12-17-2016, 9:01 PM
Ok I tried the cd antenna on the other coax on the equinox to the bearcat. No go.
I took out the bearcat upstairs to my 2nd floor apartment connected to my 2m/70 X30 antenna and I was able to hear 162.450 and162.550.
So let me know if u all agree but it's not the bearcat.
Could it be a poor electrical connection? On the equinox?
KR3LIM
WQYT778
  #25 (permalink)
Old 12-17-2016, 9:33 PM
So the reception is just not good on the bearcat unless I'm in a better position i.e. On the road.
Someone say "you're good to go"
KR3LIM
WQYT778
  #26 (permalink)
Old 12-17-2016, 9:49 PM
prcguy's Avatar
In my opinion the 980 and the Yaesu should have very similar sensitivity at 162MHz. You stated the Yaesu would hear weather channels on the vehicle CB antenna but the 980 would not.
If the weather reception on the Yaesu with the CB antenna was clear with no noise, or registered a few bars or more on the S meter, then I would say the 980 has a problem and if its under warranty take it back. For one radio to receive a signal well and another on the same antenna doesn't pick up anything, there is at least a 10dB difference and maybe 20dB or more in the sensitivity between the radios. That's not trivial and something is wrong.
prcguy
  #27 (permalink)
Old 12-18-2016, 2:28 AM
prcguy
It does sound like it's the radio. Connecting the 980 to a VHF antenna didn't necessarily eliminate the radio. As some have mentioned it might be a tuning issue. Has it ever worked since you got it?
I just bought a 980 along with a Wilson 1000 a month ago and being out in the middle of nowhere I sometimes turn on the Weather just to make sure my radio is still working, lol.
  #28 (permalink)
Old 12-18-2016, 7:49 AM
I'm flying to Texas and will send it back to uniden. CB have a 2 year warranty.
KR3LIM
WQYT778
  #29 (permalink)
Old 07-08-2017, 6:40 PM
I just setup a 980 SSB with a K40/K30 NGP antenna. I'm having really poor weather reception. My handheld Cobra 38 WXST picks up several stations with a rubber ducky while the 980 barely picks up one, and only sometimes. If CB antennas are not appropriate, why would Uniden not put an onboard antenna for the weather bands? I'm at a loss that they'd go to the trouble of adding the WX receiver, advertise, and then hamstring the performance this way? BTW, the antenna tuned to 1.30 at the extremes, and reads 1.0 thru much of the mid bands.
