Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > CB Radio Forum
CB Radio Forum - Discussions regarding Citizens Band Radio (CB)
Old 08-29-2017, 7:11 AM
Cool combination antenna mast
Can I use the same mast for CB and TV antenna ? If so what must the separation be ?
Old 08-29-2017, 8:26 AM
kc8kek's Avatar
Default TV / CB mast
You can probably get away without a problem as long as the CB antenna is mounted at the top, and the TV antenna somewhere below it. I would use decent coax (for the CB) to try and reduce interference to the TV, and possibly put a choke balun below the CB antenna to keep RF off the feedline. Google "choke balun" if you aren't familiar.
Old 08-29-2017, 2:12 PM
Thanks !
Old 08-29-2017, 4:04 PM
You should be OK as long as you're running a barefoot CB Transceiver. If you start running power you stand a chance of blowing the TV's receiver input which would be permanent damage.
Old 08-30-2017, 1:18 AM
You may want to put a high pass filter on the TV's coax line and a low pass filter on the CB coax. Together they should keep your stuff safer. I'll second the suggestion to put the CB antenna on top. The choke balun is a good idea also.
Old 09-01-2017, 4:55 PM
Thanks for your info and advice.
arkieguide
Old 09-02-2017, 4:13 PM
kc8kek's Avatar
No worries. Enjoy the hobby.
Old 09-03-2017, 7:43 AM
Thank you !
