Looking for options to mounting CB Antenna
IdleMonitor
The Ottawa Valley - Eastern Ontario
Looking to put up my Sirio Tornado ground plane antenna before winter sets in. My last place I used it I had no problems mounting it to a chimney, unfortunately I don't have that capability any longer. I'm thinking about either a tripod mount or a gable eve type mount. I would like to use either a 5ft or 10ft mast. Either or is fine as I've got some decent height working for me to begin with.
Suggestions?
If the Gable eve mount would work for me then atleast I'm not gonna be drilling holes into the roof.
Also, I'm looking to mount one of my scanner antennas to the same area only a bit lower down using a j pole type mount. Once I get these in place then I'm completely back in business to using my radios fully finally.
jonwienke
More Info Coming Soon!
VA
I wouldn't use either, given the size of the antenna. You'll have issues with wind and leaks with a tripod or gable mount
Put a mast next to your house, set the base in concrete, and secure the mast to the house near the roofline in a way that ensures it is attached to structural 2x4s, not just plywood.
radact
Las Vegas, Nv
CB Antenna Mounting
This is what I did.
As you can see I used left over dish arms and one of them has an Antron 99 on it.
The tall pole had a Commercial Dual Band that I used for MURS & GMRS and for
simplex use on those bands as well that is why I wanted it higher than the rest. Eventually it
too went on an arm.
Right after the picture was taken I got rid of the DirectTV service, took the dish off and used
that arm for a 900 mhz antenna.
They're very sturdy and if mounted like the other person advised on the stud on the back of
the eve, it supports very well.
Hope this gives some idea.
