On swr meter it has a watts reading. I guess it reads watts in coax. No reading when I tested coax center wire to ground around coax, which is good. Antenna is a Wilson little wil. Also just install new coax onto antenna. Rg8x coax. Tested all solder connections=good. Old cable had some crimps in it from door. I have rerouted the coax cable under truck thru a plastic grommet under back seat.
I also added a extra 12ga ground wire to mag antenna base. Drilled hole installed on ground post, installed on truck frame. Tested, good ground.
I'm going to recheck antenna out on back of radio again, just to make sure. (Center hole to outer male threads on antenna out).
Sent from my XT1650 using Tapatalk
