I'll add to cmdrwill…
That antenna will require a ground plane, but you may have some options…
Any large electrically conductive surface can work as a ground plane. Some who live in manufactured homes that have aluminum skinned roof materials have had good luck by sticking the antenna in the center of the roof. If you have a covered patio that has a corrugated style roof, or a shed, barn, etc, those can all work.
You can also use 3 or more lengths of wire, 108 inches long or more, stretching out horizontally from the base of the antenna in equal directions (3 @ 120º, 4 @ 90º etc).
The half wave antenna is a good option, as they will work without a ground plane. But, if you already own the Wilson, you can pick up some wire pretty cheap and give it a try.
If your roof is flat, or you have a raised flat area, you can lay down some wire, wire mesh, etc. on the roof and place the antenna in the center.
Not having a suitable ground plane is going to result in high SWR and pretty terrible performance.
